01-25-2015, 12:50 PM | #1 |
255
Rep 1,040
aFe Scrocher - 2011-2015 N55 3.0L Sensor 2
Less than 1 year old, aFe Scorcher module used on my 2014 M235i; includes factory installation manual. Can be used with other N55 engines from 2011 and on. Installs/removes in 10 minutes or less with no CELs. Free shipping to 48 US States only. Please PM me your PayPal account to send payment invoice. $300 Shipped to 48 USA states only! From manufacturer: Part no. 77-46304 Put up to 40hp and 80lbs. x ft. torque to your N55 today! The aFe Power SCORCHER Module is designed to alter the pressure sensor signals to increase turbo boost to an optimum level throughout the entire RPM range. The result is a harmonious balance between power, throttle response and drivability. This module provides a hassle-free installation with no cutting, drilling or splicing required during the 30 minute installation time. Factory electronic accessories are not affected by installing the Scorcher module. Direct Plug In Power: This simple and safe plug and play module adds instant power by altering pressure sensor signals to increase boost to an optimum level throughout the entire RPM range. Blue L.E.D. Power light: This module comes with a built-in blue L.E.D. light to show your module is powered up and functioning correctly. High Precision and Reliability: Scorcher modules are 100% tested, have output protection on all signals and are built to a 0.1% tolerance on components in critical areas. Signal filtering is used for a smooth response. These modules work great on vehicles in stock trim but are optimized to maximum performance with use of aFe Power performance parts (intakes, filters, exhaust, etc.). High Quality Materials: aFe Scorcher modules use OE style "all weather" connectors which require no modification to your factory harness, providing a secure factory-style fit and hassle-free installation. The housing is constructed of aluminum with a hard coat black anodized finish and uses Automotive grade TXL wire with high heat and chemical resistance. Scorcher Modules come with a 2-year limited warranty. Sensor 2 Style: The BMW N55 came with two types of TMAP/MAP Sensors. This Module accommodates the Sensor 2 style. The Sensor 2 TMAP/MAP sensor is identified by having a gray connector clip and no raised square located between the mounting bolt locations. See the illustration on this web page or on page 3 of the instruction manual for details. The TMAP sensor is located on the drivers side of the engine, mounted on the intake tube between the factory air box and the strut tower. Note: This information is critical to choosing the correct module for your vehicle. This Also Fits: BMW 135i (E82/E88) 11-13 L6-3.0L (turbo) N55 BMW 135is (E82/88) 13-14 L6-3.0L (turbo) N55 BMW M135i/ix (F20/21) 12-14 L6-3.0L (turbo) N55 BMW M235i (F22) 2014 L6-3.0L (turbo) N55 BMW 335ix (E9x) 11-13 L6-3.0L (turbo) N55 BMW 335i/ix (F30) 12-14 L6-3.0L (turbo) N55 BMW 335i/ix (F31/34) 13-14 L6-3.0L (turbo) N55 BMW 435i/ix (F32/33) 2014 L6-3.0L (turbo) N55 BMW 535i (F07/F10) 11-14 L6-3.0L (t) N55 BMW 640i/ix (F12/13/06) 12-14 L6-3.0L (turbo) N55 BMW 740i/Li/Lix (F01/02) L6-3.0L (turbo) N55 BMW X1 35ix (E84) 11-14 L6-3.0L (turbo) N55 BMW X3 35ix (F25) 13-14 L6-3.0L (turbo) N55 BMW X5 35xi (E70) 11-13 L6-3.0L (turbo) N55 BMW X5 35i/xi (F15) 2014 L6-3.0L (turbo) N55 BMW X6 35xi (E71) 11-14 L6-3.0L (turbo) N55 Last edited by Delnari; 02-13-2015 at 06:35 PM.. |
02-11-2015, 10:57 AM | #4 |
IG @bmwF9xG80
3810
Rep 7,594
Drives: G80 M3, X4M, G07 X7m50
bump for a great deal!
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
