01-23-2015, 01:03 PM | #1 |
114
Rep 867
MPS Knocking & Clunking noise
My local tuner shop installed a set of M performance suspenison kit and 6 days later I found out the driver side is slightly higher than the passenger side, so I took it back to the shop and have the tech do the inspection. Tech stated everything looks normal and the height difference might casued by unsattled springs. Took the car back home, 1 week later I heard very loud knocking and clunky noise coming from my front passenger side and it appares on the low speed (below 50MPH) and very consistent when drive on the bumpy road.
Since I have taken my car to the tuner shop last time and they told me everything looks perfect. This time I really don't trust them to touch my car again. So I called my SA at local BMW dealership and made a 7am appointment yesterday. Drop off the car at the morning and get a call from my SA saying both front springs are loose, and they are going to charge me $340 dollars for the labor to redo it. I was like fine as long as it gets fixed, but somehow they didn't do it at the end. The noise was gone when tech tighten all the bolts. I took the car back last night and everything was fine until I pulled into my drive way. I heard the noise again and it was all over it. Just like the same before. Again, I called my SA and drop off the car this morning. 10 mins ago my SA texted me saying they are still not able to locate the noise.
2022 BMW X4MC
2018 Tesla Model X 100D |
01-23-2015, 03:07 PM | #3 |
114
Rep 867
might be something wrong with the preload??
2022 BMW X4MC
01-23-2015, 06:10 PM | #5 |
925
Rep 3,089
01-23-2015, 06:14 PM | #6 | |
114
Rep 867
Did you order the bilstein b16 suspension yet? Let me know how it works.
2022 BMW X4MC
01-27-2015, 01:44 PM | #7 |
114
Rep 867
Updates: SA called last night and told me they've found the issues after tore apart the front suspensions. The issue was caused by the torn strut bearing rubber boot and both front springs are touching the metal thru the rubber boots and making the knocking noise. BMW confirmed the issue was casued by improper install.
2022 BMW X4MC
01-27-2015, 03:20 PM | #9 |
114
Rep 867
Actually, they are. Both labor and parts. I am going to claim it with my local tuner shop for the improper install.
2022 BMW X4MC
01-27-2015, 05:01 PM | #10 |
117
Rep 1,027
Sounds like a lawsuit will result from this, good luck man
Positive Momentum
01-27-2015, 06:02 PM | #11 |
114
Rep 867
I am gently asking my local shop to refund the moeny for the front suspensions installation and the money for the replacement parts. Let's see what they are going to reply.
2022 BMW X4MC
01-27-2015, 07:41 PM | #12 |
e92 - 335i
179
Rep 743
Definitely an unfortunate situation. It is situations like these that make me proud that I do all my own work.
I remember reading just a short time ago that someone had a shop install their springs and the shop installed the springs upside down which cause the spring to pierce through the spring pad. Good luck! |
01-27-2015, 07:52 PM | #13 | |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
01-28-2015, 02:01 PM | #14 | |
114
Rep 867
2022 BMW X4MC
01-29-2015, 12:52 PM | #15 |
82
Rep 398
Hey, at least I am glad the suspension is installed right. I did not hesitate to get mine installed at a dealer. It does cost, but you know for sure that they will install correctly or they will cover to get it done right eventually. Things such as suspension, differential, etc.. I will not go anywhere but the dealer I trust
Enjoy what the MPS offers now |
01-29-2015, 04:33 PM | #16 | |
114
Rep 867
2022 BMW X4MC
2018 Tesla Model X 100D Last edited by Sharp_Cai; 01-29-2015 at 05:09 PM.. |
04-10-2015, 08:54 AM | #17 | |
51
Rep 1,831
Drives: 335i MSport + MPS/MPPK
04-13-2015, 02:55 PM | #18 |
41
Rep 160
By the way, the uneven height between driver and passenger side is normal. From what I was told, the driver's weight will put the car more closer to the normal balance.
