BMW e90 Wheel and Tire Sizes
01-18-2008, 08:17 AM | #1 |
17
Rep 375
In my quest for after market rims and wheels, I've compiled a bunch of information because I was tired of doing the same calculations over and over agian. I hope this helps others here on this site.
OEM 162 rims Front: 8 x 18 ET34 Rear: 8.5 x 18 ET37 Front Tire Size: 225/40-18 – dimension 25.09 Rear Tire Size: 255/35-18 – dimension 25.03 M5 Replicas Front: 8 x 18 ET38 Rear: 9 x 18 ET38 Front Tire Size: 225/40-18 Rear Tire Size: 255/35-18 Notes: Fronts will have 4mm LESS clearance on the strut side, and the outside edge of the wheel will RETRACT 4mm. Rears will have 7mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 5mm $696 for rims. M6 Replicas Front: 8 x 18 ET38 Rear: 8 x 18 ET38 Front Tire Size: 225/40-18 Rear Tire Size: 225/40-18 Notes: Front will have 4mm LESS clearance on the strut side, and the outside edge of the wheel will RETRACT 4mm. Rears will have 5mm MORE clearance on the strut side, and the outside edge of the wheel will RETRACT 7mm CSL Reps Front: 8.5 x 18 ET40 Rear: 9.5 x 18 ET45 Front Tire Size: 225/40-18 Rear Tire Size: 255/35-18 Notes: Front will have 12mm LESS clearance on the strut side, and the outside edge of the wheel will extend to THE SAME point as the stock wheel. Rear will have 21mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 5mm. Front: 8.5 x 19 ET40 Rear: 9.5 x 19 ET45 Front Tire Size: 225/40-19 Rear Tire Size: 255/35-19 OR Front Tire Size: 235/35-19 – new tire dimension 25.48 Bridgestone Potenza RE960AS Rear Tire Size: 275/30-19 – new tire dimension 25.5 Bridgestone Potenza RE960AS Notes: Front will have 12mm LESS clearance on the strut side, and the outside edge of the wheel will extend to THE SAME point as the stock wheel. Rear will have 21mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 5mm. M3 EX-M4 Front: 8.5x19 ET35 Rear: 9.5x19 ET35 Front Tire Size: 225/40-19 Rear Tire Size: 255/35-19 OR Front Tire Size: 235/35-19 – new tire dimension 25.48 Bridgestone Potenza RE960AS Rear Tire Size: 275/30-19 – new tire dimension 25.5 Bridgestone Potenza RE960AS Notes: Front will have 7mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 5mm. Rear will have 11mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 15mm. Last edited by TheJackal; 01-18-2008 at 12:03 PM.. |
01-27-2008, 09:47 AM | #6 | |
1866
Rep 935
Previous notables:
'05 S2000 | '07 335i | '09 ISF | '08 911 Turbo | '09 911 C2 | '15 Cayman | '15 RCF | '17 MX-5 RF | '17 C7 Corvette |
01-27-2008, 10:17 AM | #7 | |
17
Rep 375
And for the other posts that said I 'missed' some wheels, I only ran the calculations for rims I was interested in. I din't think its appropriate to push a certain wheel in this thread. There is an entire other forum section for that. This is about fitment vs oem. Thanks. -Jackal |
