Suspension Damage? (See Picture)
01-17-2015, 04:31 PM | #1 |
Bad Driver
58
Rep 392
I was diying my fuel filter today and saw this:
This was on the drivers side (LHD) front wheel. Can someone tell me what the tear/ripped looking metal part is? Is this a safety issue? Thanks in advance. |
01-17-2015, 05:31 PM | #2 |
28
Rep 583
Looks like a bracket that's somehow involved with the headlight sensor. Doesn't look robust enough to be load bearing
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
01-17-2015, 06:47 PM | #3 |
30
Rep 399
01-17-2015, 06:48 PM | #4 |
353
Rep 1,005
Drives: GMC Sierra
How are your headlights doing at night? Too low or too high? Bouncing more than usual? Suspension looks ok. That mount on the right is for something behind the fabric cover.
We grow food to feed the animals so we can eat the animals
01-17-2015, 09:52 PM | #6 | |
347
Rep 739
2018 BMW 530e Alpine White | Black Napa Leather | Bone Stock
01-19-2015, 08:52 AM | #7 |
353
Rep 1,005
Drives: GMC Sierra
I'd say fix it before your headlight leveling motors get overworked. I am just being anal.
I disabled the auto door lock function because I don't want premature failure. I unlock the driver door with the fob and push it down manually once inside. No need to have all of the doors trying to lock when they are already locked. I'm crazy like that.
01-19-2015, 11:21 AM | #8 | |
Bad Driver
58
Rep 392
01-19-2015, 12:47 PM | #9 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
That's exactly the part that's broken, its just partially hidden behind the cover panel. Its easy to hook back up, I would just say go for it. I think you will need some torx (or maybe hex?) bits IIRC to take off the plate from the sensor.
01-19-2015, 11:28 PM | #10 |
353
Rep 1,005
Drives: GMC Sierra
You can do at!
01-21-2015, 12:08 PM | #11 |
Bad Driver
58
Rep 392
I asked my mechanic.
He thinks he can do it in 20 min or less. I will attempt on my own and create a diy. P/N: 37146763734 Last edited by m9bm; 01-21-2015 at 02:13 PM.. |
01-27-2015, 03:25 PM | #12 |
Rep 63
I just went through this. On mine the plastic crank arm for the actuator was broken and headlights were dipped down, so I had to replace it. You got lucky with yours. It's easy, you'll be fine. I don't think you can install anything backwards, but just pay attention during removal.
Good luck! |
01-27-2015, 07:08 PM | #13 | |
Bad Driver
58
Rep 392
I'm going to replace it anyways since I already bought the part.
2010 Space Gray 335d
01-27-2015, 07:49 PM | #14 |
30
Rep 399
I should have kept checking this tread.
That damaged bracket would not cause bouncy headlights. The movement of the pivot arm on the leveler that is attached to the control arm will negligibly more frequent due to that crack. Simply, there isn't enough flexing in that bracket to be causing it. I would more suspect to improperly installed bulbs and worn out suspension part, like control arm, strut, and strut mount. Also, worn out leveler itself and too high tire pressure. My headlights were bouncy, but not any more, after I replaced all the suspension at 60k |
01-28-2015, 10:29 AM | #15 |
king of the hills
92
Rep 2,915
There is a TSB out there for the "bouncy or shaky" headlights, with a retrofit bracket to help remedy the situation. Not sure if it applied only for E92, but could be worth a search for it (I had it installed on my E92 and it made it go away.
Agreed with above, even though the sensor arm is not attached to your control arm, it may not be the actual cause of the bouncy headlights...but its still broken regardless so I would definitely start there. |
01-29-2015, 03:11 PM | #16 | |
Bad Driver
58
Rep 392
There wasn't any info on DIYing the bracket retrofit I believe.
