01-13-2015, 07:44 PM | #1 |
267
Rep 554
DIY: Removing Sunvisor Decals
I can't stand looking at the unsightly Sunvisor Warning Decals so I thought I would create a little how-to for others showing what I feel is the easiest way to remove them. (WARNING: Remove OEM warning stickers and mattress labels at your own risk. Death, injury and hefty fines may result.)
Items needed: -91% Isopropal Alcohol (70% is not strong enough) -Small sponge -Plastic pry tool -T20 Torx driver 1. Using pry tool carefully unsnap the hinged screw cover. 2. Remove screw with Torx driver 3. The hinge is now loose but must be rotated forward and pulled out of the rectangular mounting hole. Note electrical connector that is snapped into the side of the hinge. 4. Pull the electrical connector free from the hinge. Now unsnap the two halves of the connector and remove the visor from the car. 5. Soak the sponge in the alcohol and soak the decal. Be patient. Keep it wet. You can even walk away for a couple minutes if you desire. After 3-5 minutes the decal will start to shrink and loosen. 6. Scratch a corner loose with your fingernail and start to slowly pull upwards. Keep soaking the decal as you pull. Work slowly, the goal is to pull the decal off in one piece. It will all pull off in about 1-2 minutes. 7. You will end up with the entire sticker shriveled up in one piece with no residue left on the visor. 8. Much better!
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
14
hoppy6698127.00 mwickens63.00 aerodavew9.50 mrgarysteel0.00 omega14587.50 Nyorky242889.50 Tyresian69.00 stevenvillatoro734.50 shil31.50 ///M Houbi1653.00 bluesman826646.00 nixeighty6118.00 |
03-20-2015, 05:16 PM | #2 |
Rep 13
Drives: 2015 M231i Glacier Silver
Nice DIY
Done in 5 minutes. You're tip on the stronger alcohol concentration is the key, I think. Didn't even know it came in more than one strength. I wonder, will this tip work with alcantra covered visors like in the X4?
03-22-2015, 10:23 AM | #5 |
1836
Rep 4,204
Did mine today ...took me way more than 5 min but I think I purchased some falsely advertised alcohol
03-22-2015, 12:44 PM | #6 |
267
Rep 554
No, never have seen this. Been successfully using this procedure for well over 10 years.
The Stable
03-22-2015, 07:21 PM | #7 |
10
Rep 34
03-24-2015, 06:31 AM | #8 |
26
Rep 78
Thanks for posting, pics and all very easy laid out process....looks simple and I too hate those warning stickers... Got everything apart... almost.
Step 4 has confounded me.. I cannot figure how and where to pry or where they come apart/unhook....perhaps poor eyes, but can't figure it out.. don't want to break it as it seams at least over engineered to be difficult, lol. any suggestions would be helpful! |
03-24-2015, 07:38 AM | #9 |
267
Rep 554
To split the small connector from the large connector I inserted an Xacto knife down the side of the small connector and into the large connector only about 1/8" then simply pried outward to pull the small connector out. It takes some force but it will separate and does not break. It needs some force to overcome the internal barb. You could try a tiny jewelers screwdriver, too. It just needs to be very thin.
hoppy6698127.00 |
03-25-2015, 08:10 AM | #10 |
20
Rep 93
Drives: 2015 M235i
This is a great post, thanks for the detailed process and photos. Works like a champ. My label didn't actual shrivel or anything, after 5 or so minutes I just started gently rubbing one corner with fingertip, it started rolling up with no issue.
05-16-2015, 01:40 PM | #12 |
26
Rep 78
Step 4... Granted I am an idiot, I cannot figure out how to "unsnap the connector"... Can't even find a pic of what each sde looks like. Why on god's earch would someone make a cnnector so complex? Seems rediculous.
Have tried gently pulling, wiggling, even tried an exacto knife tip, (which broke the point off btw). I almost just cut the wires... While I understand my place in the world, this stupid connector and the annoying stickers will not beat me! Help?
2015 M235i White with Black interior loaded except for DA+ and LSD
05-16-2015, 03:14 PM | #13 |
267
Rep 554
^^^ Hang in there! You can do it. IIRC the female half if the connector, the larger side, stays with the sun visor once removed. While holding the connector I inserted the blade into the flatter side of the connector. Insert the blade the tiniest amount. (I think you inserted it too far which just wedges things tighter) just "prick" the connector and it will pull out.
You're so close! Just use patience. You'll laugh once you see how simple it really is.
The Stable
05-16-2015, 06:02 PM | #14 |
Rep 77
Thanks. This worked for me. Took a few extra minutes on one side though.
The connector was pretty easy. Thin flat head worked to separate the pieces. I should have taken a pic to remember where exactly I disconnected. Last edited by b_ack51; 05-16-2015 at 06:08 PM.. |
05-30-2015, 10:58 PM | #15 |
1416
Rep 2,519
Drives: 2011 328i Wagon
Do you suppose if I did this while I am still on my Euro Delivery trip that the port would "fix" it before re-delivery?
This was the second mod I did to my 328i wagon upon re-delivery. 15 minutes after I got it home. The very first was the ZHP shiftknob, which I did while the car was still on the turntable at BMW Welt!
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
06-14-2015, 02:50 AM | #16 |
NewFinishColumbia/detailer
604
Rep 2,096
Doing this for sure. I really hate this stickers.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
wiggy1.50 |
07-06-2015, 11:02 AM | #18 | |
267
Rep 554
The Stable
09-03-2015, 12:17 PM | #20 |
103
Rep 107
Did this last evening, there was some initial shadowing but that was because the sticker didn't come off very cleanly and left some residue behind. I found regular old acetone (not nail polish remover) quickly removed the residue left behind without much fuss.
Thanks for posting this up! |
10-09-2015, 05:47 AM | #21 |
Rep 15
wicked tutorial, my torx bolts were t25 though, t20 was loose, looks so much better now thanks!
Jake@mpengieering.co.uk |
06-24-2016, 06:44 AM | #22 |
282
Rep 707
I will be giving this a go soon. Great write up
Current: 2016 Golf GTD with a "lot" of toys
Gone: 2016 M3 CP - Mineral Grey / Black Gone: 2009 135i - Le Mans Blue / Black |
