Complete bushing replacement-what's needed?
01-12-2015, 05:38 PM | #1 |
2033
Rep 8,339
Ok I've been getting bits and pieces from different threads but never seen a complete list in one spot. My car has 200,000 miles. I'm redoing it with a complete set of FBO, turbos, suspension, brakes, etc. in the process I want to replace all the various bushings and get it tightened up again. So far I am replacing:
Subframe bushings with AKG black bushings Motor and trans age getting new OEM mounts I'm replacing coilovers with KW v2. I'm guessing they come with all new necessary shock mounts etc for refresh. What other bushings need replacing? differential? Front Control arm? read control arm? Rear upper link? Rear guide rod? Sway bar? Would replacing bushings in some of these locations be so expensive that I may as well replace the part with M3/TRW verions with the bushings installed? Not really interested in replacing sway bars if I'm not going to get better cornering grip, but the rest maybe if it makes sense. I am interested in a shock tower brace, maybe M3 also. Any other locations I need to address? Any of these not need replacing? Where's my suspension gurus? Oh and the general idea is to get it to handle as well or better than an M3 version of my car.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
01-12-2015, 08:48 PM | #2 |
2033
Rep 8,339
62 views and nothing yet?
01-12-2015, 09:26 PM | #3 |
30
Rep 40
I'm assuming you are referring to the rear subframe bushings where you'll use the AKG black bushings, right?
I'd recommend the differential mounting bushings since higher power levels will wear those down. Also get the M3 front control arms, which come with new bushings & are lighter (aluminum) and give about -0.7 degrees camber. The strut mounts and the bump stops on your suspension should be fine if you don't expose them to snow & the associated crap they put on the roads. The integrity of the bump stops are easily verified when you have your wheel off. I live in Houston, and due to the mild weather conditions, I didn't need to change them out. This being said, I honestly don't think that you'll get to equal/better handling than the M3 without substantial investment, but if that's your aim, go for it! I'd consult with Harold @ hpashop if that's your goal. |
01-12-2015, 09:48 PM | #4 |
2033
Rep 8,339
I've been making substantial investment. Well over $20,000 in upgrades so far. Rear wheel hp is going to be around 650. Figure lowering, same size but better tires, m3 or better components front to rear, should be doable. Harold is doing my wavetrac LSD. I'll talk to him about the other stuff too.
01-12-2015, 10:24 PM | #5 | |
1234
Rep 3,778
Drives: '11 328i '19 M6
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
01-13-2015, 12:54 AM | #6 | |
2033
Rep 8,339
01-13-2015, 08:18 AM | #7 |
1234
Rep 3,778
BimmerWorld has them.
01-13-2015, 10:45 AM | #8 |
164
Rep 2,556
KW don't come with shock mounts. You'll need those. Dinan or Powerflex rear upper mounts and oem rear lower mount. Might as well get new upper strut mounts too. Did you mention toe arms? Megan Racing seems to be the best bet. Possibly a differential lockdown kit with all that HP or at least firmer diff bushings.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
01-13-2015, 10:53 AM | #9 |
1234
Rep 3,778
FWIW, Turner has lower shock mounts for Heim joints -- http://www.turnermotorsport.com/p-20...m-e82-e9x.aspx
And AKG makes upper shock mounts as well.
01-13-2015, 11:11 AM | #10 |
164
Rep 2,556
^ Those won't work for non-M rear shocks. He's getting KW V2
01-13-2015, 11:32 AM | #11 |
1234
Rep 3,778
OK, thanks. The dampers on my car use them or something that looks a lot like them and the spring arm is stock. Turner's page says they'll work with an '08 335i E93.
03-03-2015, 11:03 PM | #12 |
21
Rep 115
Drives: 2011 535i (6sp)
Hey Pete, impressive list of mode there. Since we're in a bushings thread thought id throw in the question:
"How do you like the TMS Delrin\Aluminum rear subframe ("RS") bushings?" I'm debating, I'm sure I'm not alone, with M3 upgraded, BMW Group N motorsports rubber, or the TMS Delrin. Also, did you DIY? Thanks! |
03-03-2015, 11:32 PM | #13 | |
1234
Rep 3,778
Didn't DIY, all the work was done by a local SCCA race team, part of the dealership I bought the car at. Since the subframe has to be removed you have to know how to index it which turns out to be an alignment of the rear subframe with the front subframe, apparently not a trivial exercise but they do it all the time so it wasn't a big deal for them. Wouldn't want to attempt that at all if the idea was to get the best rolling chassis setup possible. YMMV of course. Me, I've mucked up enough DIY along the way that I've found it less expensive to get it done right the first time.
