E90xi KW V1 question
01-08-2015, 11:01 PM | #1 |
38
Rep 427
Going to be purchasing a set of KW V1's pretty soon and was just wondering if I'll need anything else ride quality wise aka camber plates(if they even make them for my car) also if I'll need to replace bumpstops, just don't want it to bottom out at all. Any suggestions would be appreciated. Car is 2011 e90 335 X-Drive.
Thanks guys |
01-11-2015, 09:03 PM | #3 |
261
Rep 1,093
You don't need camber plates unless you are trying to add negative camber out of factory spec (more than -0.5) for performance reasons. You could use M3 arms to achieve -1.5 camber. Basically unless you racing there is no need for camber plates but if you wanted a street performance upgrade you would use M3 arms to get another -1.0 deg of camber. The coilovers come with their own bump stops.
01-11-2015, 09:07 PM | #4 | |
38
Rep 427
01-11-2015, 09:34 PM | #5 |
56
Rep 1,465
Drives: 2009 BMW 335xi
Front m3 arms nor sway bar fit the xi. Only the rear m3 bits fit. You won't need camber plates or bump stops to run the v1s.
