Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Front wheel bearing
      01-08-2015, 09:54 AM   #1
AdzC
13
Drives: E92 335d
Front wheel bearing
I believe the front nearside wheel bearing has been on it's way out for a while and I am thinking of getting it replaced.
Does anyone have any knowledge of how easy this is to replace as a DIY? Am I right in thinking that it's a case that the bearings are bolted into the job rather than pressed in like traditional bearings?
Thanks
Space Grey E92 335d
1998 Yamaha R1
      01-08-2015, 03:01 PM   #2
tmarshall57
tmarshall57's Avatar
56
Drives: F10 530d M Sport, E87 118d M
The front bearing is located in the hub which is detached by removing 4 bolts. The bearing/hub is a single unit. There has been discussion on here relating to the relative merits of different bearing manufacturers but you should be OK with SKF or F A G
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
      01-08-2015, 03:07 PM   #3
AdzC
13
Drives: E92 335d
Thanks for the reply.
I take it there is no requirement for a press then and should be a relatively straight forward DIY job?
      01-08-2015, 03:17 PM   #4
tmarshall57
56
Yes - no need for press
Looks like this
http://www.carparts4less.co.uk/cp4l/...f10fb35&000370
      01-09-2015, 06:19 AM   #5
Hulla the Hulla
19
Drives: E91 335d
the old bolts can be tricky to get out (so I've heard)
      01-09-2015, 02:10 PM   #6
AdzC
13
Drives: E92 335d
Is that because of the thread lock used on them?
Space Grey E92 335d
1998 Yamaha R1
      01-10-2015, 01:06 PM   #7
Jeff123
Jeff
318
Drives: 330d M Sport x-drive F30
I thought that mine was on its way out - turns out it was road noise from some old Falken tyres, that disappeared once I changed them.
Could it be that?
      01-12-2015, 06:38 AM   #8
Hulla the Hulla
19
Drives: E91 335d
yep - make sure you have a good sized breaker bar handy
      01-12-2015, 06:40 AM   #9
Hulla the Hulla
19
Drives: E91 335d
Could it be that?
worth checking as I've heard about tyres "feathering" the tread blocks which can be noisy
