01-06-2015, 03:28 AM | #1 |
10996
Rep 32,881
AC Schnitzer Spring Install DIY 330d SDrive
My ACS springs arrived yesterday so as there was a few hours of daylight left i thought i'd get started.
Something i found was the spring compressors i had (first picture) will not work on F30 springs! So after much faffing about trying, i gave up and went to a shop to buy some different ones, in my girlfriends car, which i had to walk 15 minutes to her work to borrow! Anyway, once i had the right tools (second picture) it was fairly easy! The only difficult bits are getting the strut out of and back into the wheel carrier as you have to lever the clamp seat open at the same time as pushing the wheel carrier down, or pulling it up. And getting the end bolt back into the rear suspension camber arm needs a bit of faffing with raising the hub assembly with a jack. Also i'm glad i've got two trolley jacks as the F30 doesn't appear to have a front central jacking point, and there's nowhere for axle stands to go! Maybe there is if you remove some of the underbody plastic covers but i just found it easier to jack it up both sides and place axle stands next to the jacks just in case. I used a combination of these two guides: http://preisliste.ac-schnitzer.de/ac...3130230310.pdf http://f30.bimmerpost.com/forums/att...3&d=1401934841 I followed the ACS guide, but used the special tools (i used a 18mm spark plug socket with hex top instead of his bodged angle grinded socket) & torque settings & a couple of other bits from the other one, and instead of grinding a socket bit i bought one of the for the strut top nut: http://www.ebay.co.uk/itm/2715191901...%3AMEBIDX%3AIT So i got one corner done then it got dark so will continue today and update then. Update: The other front one was very easy after getting the right tools & the knowledge gained on the first one. Rears are fairly easy except for getting the outer camber arm bolt back in! It takes a fair bit of trial and error. So i did the front left in 4 hours including going to get the other clamps, the front right in 1 hour, rear left in 1 1/4 hours and rear right in 45 mins, so total was 7 hours. For someone with similar mechanical experience to me doing this for the first time and with the correct tools it should take around 5 hours. I could do it again right now in under 4 hours. Last edited by teaston; 02-18-2015 at 09:40 AM.. |
01-06-2015, 03:59 AM | #2 |
General Motors
237
Rep 513
Drives: 430d M Sport + EBII
Did you happen to take any pictures? I have ordered the springs in preparation of my cars arrival. It would be good to have an image or two prior to see.
At this rate of buying things, my first day of ownership will be spent pulling it apart!
430d M Sport Plus, 19" M double spoke bi-colour wheels, stop start cruise, pro navigation, sport auto, dynamic suspension, folding/dimming mirrors, rear camera, power seats.
Previous - S5 Cabriolet - 442hp |
01-06-2015, 04:02 AM | #4 |
10996
Rep 32,881
I've just updated the OP with links to the 2 guides i used which have pics in them.
01-06-2015, 04:29 AM | #5 | |
General Motors
237
Rep 513
01-06-2015, 05:05 AM | #6 | |
922
Rep 2,559
http://shop.ac-schnitzer.co.uk/where-to-order-4-w.asp |
01-06-2015, 05:05 AM | #7 |
The artist formerly known as AC Schnitzer UK
3610
Rep 4,518
01-06-2015, 05:17 AM | #8 | |
Supreme Being
1806
Rep 5,425
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
01-06-2015, 05:37 AM | #9 |
General
8569
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Teaston, maybe just do the rears and the give it a test drive... Might dial out some understeer!
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
01-06-2015, 07:38 AM | #10 |
3533
Rep 11,292
Is it safe to drive without having the KDS alignment done? I think he said he is getting it done - but you've got to drive it there!! Would you notice much difference?
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
01-06-2015, 08:29 AM | #11 |
3105
Rep 7,032
Drives: 335xd Msport +
01-06-2015, 08:33 AM | #12 |
3105
Rep 7,032
Am imoressed btw with your willingness and ability to do maintenance work teaston
01-06-2015, 08:48 AM | #13 |
3610
Rep 4,518
Yes it's safe. It's only a check as fitting springs doesn't alter the geometry, but worth doing just in case the car was out of alignment before the springs were fitted. BMW recommend it is done when any suspension work is done.
01-06-2015, 09:58 AM | #14 |
10996
Rep 32,881
01-06-2015, 10:09 AM | #15 |
10996
Rep 32,881
I found i had to loosen the inner camber arm nut to get the outer bolt back in so that has put the alignment way out, namely the rear camber & the front and rear toe in, so everything except front camber basically!
01-06-2015, 10:09 AM | #16 |
General
8569
Rep 19,982
Good work! So away for a good test drive now?
01-06-2015, 10:13 AM | #17 |
10996
Rep 32,881
01-06-2015, 10:15 AM | #18 |
General
8569
Rep 19,982
There's no way I'd be able resist a good test drive if I just spent 6 hours under a car!
01-06-2015, 10:16 AM | #19 |
2010
Rep 6,065
01-06-2015, 10:16 AM | #20 |
10996
Rep 32,881
01-06-2015, 10:25 AM | #21 |
General
8569
Rep 19,982
I guess that's the ultimate sign of great drivers car... Makes you want to take the long way home!
