2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) How do you remove the front BMW badge?
      01-04-2015, 03:28 PM   #1
NEUE02
NEUE02's Avatar
267
Drives: M235i
I am prepping my new M235i for a full front end clear film application and would like to remove the emblem so there are fewer seams. Any ideas if it is simply popped it with studs into grommets, clipped or glued on? I tugged a bit and it doesn't give.
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S
      01-04-2015, 04:33 PM   #2
zipphreak
No_Country
454
Drives: m235xi
Have you tried heating it up. it's probably a strong adhesive. Hair dryer or heat gun should do the trick.
      01-04-2015, 04:57 PM   #3
F22santiago
48
Drives: Estoril Blue 6 Speed M240i
You need the plastic straps that boxes come tied in. We use those at the dealership. You just place it under the badge carve the strap deeper towards the center of it and then just pull up. We have been using that method on every single bmw its the easiest fastest way.
      01-04-2015, 05:10 PM   #4
NEUE02
NEUE02's Avatar
267
Drives: M235i
Thanks guys. Another question, what do you re-attach it with? Is 3M double sided tape too thick?
The Stable
      01-04-2015, 05:38 PM   #5
F22santiago
48
It comes with pins. If you pull it the right way they should stay on
      01-06-2015, 07:07 PM   #6
NEUE02
NEUE02's Avatar
267
Drives: M235i
Well, as it turns out, the hood roundel is attached by a ring of adhesive tape. It took a bit of pulling to pop it off but it worked. The best way to remove it was to loop nylon string around the top and bottom edges and pulling straight up.
The Stable
      02-24-2015, 01:12 PM   #7
jwr0721
jwr0721's Avatar
180
Drives: 2010 135i 6MT
You just made a big mistake. Wish I'd seen this earlier. You may get your roundel back on but it won't stay.
I had to have a new bumper and the BMW certified repair shop told me they would have to put on a new roundel because the old one won't ever stay once it's been removed.
      02-24-2015, 03:42 PM   #8
NEUE02
NEUE02's Avatar
267
Drives: M235i
Your tech isn't paid to re-use parts! My Roundel isn't going anywhere!
The Stable
      02-26-2015, 07:26 PM   #9
Autobot
Autobot's Avatar
84
Drives: 15 F22 M235 6MT
Thanks for the tips on removal!
Delivered 28 May
      08-04-2016, 05:41 PM   #10
zhihong.james
31
Drives: 2017 M2 6MT
What exactly did you use to reattach the emblem back to place?
Thank you.
      08-04-2016, 06:08 PM   #11
NEUE02
NEUE02's Avatar
267
Drives: M235i
I popped it off and simply reattached without doing anything. The "stickie" part on the back of the rounded pulled off cleanly from the car and it was able to be reapplied later. (In my case a few days later after the clear bra was applied to the front end.)
      08-04-2016, 10:02 PM   #12
zhihong.james
31
Drives: 2017 M2 6MT
thank you.
I guess I just need to be careful when take it off. so I do not damage the double sided tape for reuse.
      08-05-2016, 08:58 AM   #13
zhihong.james
31
Drives: 2017 M2 6MT
Do you just stick it back on top of XPEL film? How well does it stick on compare to the paint surface?
      08-05-2016, 04:55 PM   #14
Pparana
463
Drives: 2015 m235i
you would trim the expel film and then place. You could also replace the tape if you wanted, that's what most body shops do, and then charge you for a new one.
      08-05-2016, 06:40 PM   #15
Pparana
463
Drives: 2015 m235i
      08-06-2016, 10:46 PM   #16
NEUE02
NEUE02's Avatar
267
Drives: M235i
Yes, right back on the Xpel. It's going nowhere. I even blow the moisture out from underneath with an air compressor after weekly washing.
The Stable
      08-30-2016, 04:07 PM   #17
BEM-S4
BEM-S4's Avatar
4516
Drives: Dinan M235, Dinan Sport Wagon
Thanks for the good pics, very helpful. If I close the deal on a new vert this week will be ordering a new custom roundel was wondering if I should install myself or have the dealer do it. This seems easy enough.
      08-30-2016, 04:11 PM   #18
NEUE02
NEUE02's Avatar
267
Drives: M235i
It's a piece of cake. Block out 10 minutes in your day and your set. And block out 10 more so you can stand back and admire your work!
      09-01-2016, 12:12 PM   #19
BEM-S4
BEM-S4's Avatar
4516
One question for you - do the alignment "nubs" for lack of a better term contact before the adhesive? So can you get it perfectly positioned easily before making it permanent?
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      09-02-2016, 06:37 PM   #20
NEUE02
NEUE02's Avatar
267
Drives: M235i
Yes. No chance of getting it wrong. And if you just lightly touch it down, it can be popped up and off again and repositioned, if necessary. Once you are happy just push it tight.
Good questions, I wondered the same thing. But it's easier than you imagine!
The Stable
      09-08-2016, 04:57 PM   #21
BEM-S4
BEM-S4's Avatar
4516
Great, thanks again for the help. Trying to get a car to match dad's 2006 330ci (which has 32k miles if you can believe it). Got him a custom roundel made with his initials instead of BMW, I wouldn't necessarily just do the same for mine but since he'd get a huge kick out of it I probably will. Now if these thieving bastards at the dealership will just send me my paperwork...
2addicts
