Is It Possible To Have Front HID Lights?
01-02-2015, 07:44 PM | #1 |
Rep 126
Basically i have a E90 320d on a 08 plate and want to upgrade my head lights which are the standard halogens, due to the fact on my previous car I had xenons and it seems a bit dull and feel like i had candles for head lights.
So I'm wondering is there a HID kit that fits with no trouble with MOT'S, or warning lights etc? Thanks |
01-02-2015, 08:32 PM | #3 |
26
Rep 358
Yes there is, can get via eBay look for Cambus compatible systems specifically for the E90 aka search E90 HID and look to check they fit said car
To pass an Mot properly youl need to source auto level sensors and install then along with headlight washers to pass an Mot .. that's to pass it completely by the books.. a lot of people ahem get it passed through a sound tester they know but the auto levels imo are important otherwise you will be blinding people coming the opposite way |
01-03-2015, 03:44 AM | #4 |
529
Rep 2,503
Can you clarify exactly what you are talking about?
1. New headlight clusters? With Xenon HID ballasts / bulbs etc third party or OEM? 2. Crappy HID kit for halogen clusters which will blind every one else on the road? If 1, my understanding is you do not need washers and levelling sensors. I was told that MOT states, auto levellers and washers are present they MUST be working. If they aren't present it doesn't matter. Or something to that effect. You can pick up a pair of OEM Xenon for under £600 now on eBay. They will auto adjust to an acceptable angle. Coding will also be required. Fitting is pretty simple by just removing bumper. 3rd party units are ok as well, not 100% perfect fit but a lot cheaper at around £300. You can fit washers and levellers. If you really want. This won't be cheap. If 2, everyone will hate you. HID bulbs in halogen headlights are annoying for everyone because of the beam pattern. |
05-19-2015, 03:22 AM | #6 |
175
Rep 1,596
Sensible pretty much nailed it.
Retrofitting those nasty ebay kits into a reflector headlamp is an awful way to go, you lose all beam control and the glare blinds all oncoming traffic. Yes, you can now see better, but no-one else can see and your running a big risk of getting stopped by the fuzz. Your options are either to buy a proper set of BMW HID headlamp units, or, to retrofit HID projector assemblies into a halogen headlamp unit. As for washers and levelling, its a sorta weird area. British law doesnt allow HID headlamps. Manufacturers fit them using a European type approval scheme which overrides british law, and that type approval states that HID's can be fitted so long as the headlamp units are approved for HID use, and the vehicle is equipped with headlamps washers, and self levelling, either inside the headlamps, or for the whole car. The MOT however is worded differently. The MOT test says "cars fitted with HID headlamps may have headlamp washers and self levelling systems. If these systems are fitted, they must work". Clearly that leaves the door open for the car passing if the systems arent there at all. However it doesnt remove the type approval requirement. Essentially its illegal to use them without washers and self levelling, but you will pass an MOT like that just fine, and in reality your very unlikely to ever have a problem with a properly installed setup with proper HID projectors. It would take a very eagle eyed copper to notice that you dont have washers, and finding the self levelling parts is more than anyones going to do at the side of the road. |
05-19-2015, 05:29 AM | #7 |
Rep 14
You have the standard reflector headlights? Look for HID kits that are Smart Canbus compatable and are H7R. H7 is the lamp type and the R stands for reflectors. www.hids-direct.co.uk is where I got mine.
Pretty simple install, don't have issues with blinding other drivers (I even checked with someone as I HATE that from other cars) are they are setup for reflectors and have no problems with MOTs, especially since the wording in the test is so vague. |
05-19-2015, 06:20 AM | #8 |
Rep 32
If you have the standard reflector type headlights don't do it.
HID's send light out all over the place whilst halogen bulbs direct light a specific way which is why aftermarket HID's in reflector headlights scatter light everywhere and blind oncoming traffic.. If you really want xenons do it properly and source xenon headlights with level sensors and headlight washers, there's a few threads on here where people have done it. you won't have to faff about changing bulbs over for mot every year too. |
05-19-2015, 08:04 AM | #9 |
26
Rep 351
05-19-2015, 10:54 AM | #10 | |
471
Rep 1,268
I have enquired about led crees as well, they are technically legal UNTILL the MOT people update their rules. These are probably your best bet but im having trouble finding a kit that can be fitted without any modification. Cheers |
05-20-2015, 02:35 PM | #11 | |
Rep 14
This is what I got: http://www.hids-direct.co.uk/new-pre...canbus-system/ Does mess with the radio signal though, need to sort that out with some shielding or grounding etc. |
05-22-2015, 04:09 AM | #12 |
840
Rep 1,993
Drives: F30 335d
Link to my xenon conversion - expensive, but the best way IMO
http://www.e90post.com/forums/showthread.php?t=912413 |
