F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > QUESTION: P0597 Thermostat Heater Control Open
ARMA SPEED
      12-22-2014, 06:01 PM   #1
Zirenz2006
Zirenz2006's Avatar
1535
Drives: G80 M3 Comp IOMG
P0597 Thermostat Heater Control Circuit Open
I just read this code with my ODB scanner. From what I read the thermostat is designed to fail in the open position.
Is it safe to drive with this code?
I can't get an appointment until next Monday between being booked and the holidays.
Just wondering if I shouldn't be driving the car at all.
Thanks
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue
Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i
      12-24-2014, 01:32 PM   #2
flyguy27
flyguy27's Avatar
40
Drives: 2013 328I Sportline
2013 BMW 328i  [0.00]
I had my thermostat replaced and cooling system bled back in nov. I was able to get the car in the day the check engine light came on. Your car will be ok to drive, itll just take it engine a lil longer to warm up.
      01-13-2015, 07:11 PM   #3
f30luxline
e92 - 335i
179
Drives: thisonetimeatbandcamp
How did it go?
I had this same issues resolved a few weeks ago at the dealer. There is a heating element located within the thermostat housing. I was told when this element fails the system is designed keep the thermostat open. This element is supposed to aid in heating the thermostat.
I drove for about a week without issue. The only con is that it takes long for the car to come to operating temps.
      01-15-2015, 04:14 PM   #4
Zirenz2006
Zirenz2006's Avatar
1535
Needed a new thermostat, all set now. I was able to drive it int he open position until it was replaced.
      10-22-2015, 08:31 PM   #5
CarlosC
18
Drives: 2012 BMW 328i
Where exactly is the thermostat located on F30? (328i/N20)
      10-23-2015, 11:45 PM   #6
Rbrtito
Drives: 2012 328i sport line
The thermostat is located below the air box. If you remove the air box look straight now and you'll see the thermostat has one larger hose connection on top and one small one on the side of the thermostat and a large one on the bottom
f30post
