auto box issue after fluid change
12-19-2014, 03:09 PM | #1 |
Rep 91
Evening all. I have a 330d LCI with zf 6hp26 auto box. I changed the fluid and sump/filter about 1 month ago with an aftermarket kit with meyle atf to the correct spec/BMW part number. I did this as per zf procedure whilst monitoring temp via inpa, then rest adaptations. It's been driving really nicely but when using the paddles over the last 2 days noticed a jolt from 4th to 5th when accelerating up hill. I purposely tested this again this evening and same thing along with transmission warning message whilst it locked itself in a gear!! Basically shat myself, switched on/off and all seems OK in D again now.
Any ideas?? I know I need to take a look for leaks and recheck fluid levels but really hope it's not up shit creek!? Hoping the meyle atf isn't the cause as have heard of other successful changes with this? Any info or experience greatly appreciated |
12-19-2014, 06:59 PM | #2 |
105
Rep 2,692
U need to get the adaptions reset. A1bn in stevenage is yr guy
You can do a softer reset: Key in ignition Press start button (foot off the brake) Then hold accelerator pedal down for 30 secs Should see a noticeable difference |
12-20-2014, 02:54 AM | #5 |
886
Rep 9,097
I have done a lot of work on my car.
But when it comes to tranmission, I would have taken my car to old grey steve (if he is really old and got grey hairs )
12-20-2014, 03:57 AM | #7 | |
283
Rep 2,796
Once done re set adaptations yet again(advise engine adaptation re set too as the engine gearbox contrary to popular belief talk to each other too)and then go through the re learn driving experience to see if this has helped. If it hasn't then rather than DIY you'll need to get the car to some one like ourselves to see what is going on. Steve Last edited by old grey steve; 12-20-2014 at 04:24 AM.. |
12-20-2014, 09:14 AM | #10 |
283
Rep 2,796
Approx 2 hrs labour plus cost of sump kit. Worth remembering some places do the change that's it and some like ourselves also re set the required adaptations as we've learnt this makes a big overal difference
12-20-2014, 01:55 PM | #11 |
283
Rep 2,796
im under 50 got a grey car (white hair though-gone past they grey stageand me names Steve
12-20-2014, 02:05 PM | #12 |
886
Rep 9,097
Just as I thought
12-27-2014, 11:05 AM | #14 |
Rep 91
Steve, I've revisited this today and cannot get any more fluid in (roughly 5.5 litres). I followed the zf procedure. Engine running, shifted through d,r,3rd no more fluid will go in at 35degrees.
12-27-2014, 12:28 PM | #15 |
DIE ANTWOORD
68
Rep 640
I also got 5,5 litres in on the first drain. I flushed 3 times and after the 3rd time I reved the engine for about 30 seconds in order to fill the torque converter and then was able to pour another 1/2 liter in. I think 6 liters is maximum unless one drained the TC completely by removing it from the car.
12-27-2014, 04:18 PM | #16 |
Rep 91
Thanks whiteblue, seems this is about right quantity. My issue could be a valve body mechatronic solenoid after researching this. Only gives me an issue when in manual mode but still a problem as I like things to work correctly. I may have got slightly more fluid in so well reset adaptions and see what happens. Steve, where are you in the uk and what company( pm if not able to post).
12-29-2014, 01:04 PM | #17 | |
283
Rep 2,796
Best advise I can give you is get it to someone who can look at the car to get some closure on the issue |
12-29-2014, 02:40 PM | #18 |
DIE ANTWOORD
68
Rep 640
I had the car on jack stands and the pan water-leveled. Don't know wether the pan is also level when the car stands on wheels or sits on a lifting ramp. If the car is 4" higher on the rear end there will be an additional1/2 liter going in (ZF advise for the 5hp18)
Keep in mind that the fluid level changes due to g-forces when accelerating or braking and while going uphill/downhill. So 1/2 liters more or less really shouldn't be an issue.
King of the road says you move to slow
12-29-2014, 07:31 PM | #19 |
Rep 91
Actually after doing some measuring I may have got some more fluid in, so far as fyer this the boxvseems fine accelerating as before in manual mode between 4th to 5th but will test more to be certaun.
