12-15-2014, 06:25 AM | #1 |
23
Rep 115
Drives: 2015 M4 6MT
Cleaning leaves out of radiator?
Is there an easy way to access the radiator behind the lower grill in the front bumper? I've picked up a few leaves in there and it would be good to clean them out, but I don't see an easy way to access that area.
12-15-2014, 03:02 PM | #2 |
1003
Rep 3,396
^Same here, plenty of them.
Have gotten down and looked, the cavity is like a vault with no easy way in while in your driveway and on your back. With a lift I assume you can remove some panels from below, but as always it's so overbuilt that it looks like a pain. To bad the lower front grills don't just pop out, or do they? That would make it simple. I ended up using a long small diameter wood doll rod to help guide some of the debris to the front and then used long needle nose to pull some of the larger leaves out. But use caution with this technique, not to damage any cooling fins. Anyone else have any good ideas here?
12-30-2014, 09:30 AM | #3 |
344
Rep 573
^^^I did the same thing! Used a flat head screwdriver and needle nose. Pain in the butt! I pulled out some weird bugs and leaves that I picked up in Europe. There must be an easier way...
01-06-2015, 08:02 AM | #5 |
37
Rep 145
I just bought 18" fish-tank tweezers from Amazon to try that out. I will report back once I receive them and actually get out in the cold to try them out.
2017 BMW M3 6MT Comp
2002 Porsche 911 Turbo 6MT 1972 Corvette Stingray |
04-02-2015, 06:02 AM | #6 |
Jackyl22
23
Rep 96
How did this work out?
2015 BMW M3 AY
04-02-2015, 03:03 PM | #7 |
37
Rep 145
Actually haven't had to remove any leaves/debris yet, but I did try the tweezers and they fit inside the grill and reach the radiator. Copy/paste this in the Amazon search bar "18.6" Long Stainless Steel Curved Tweezer for Fish Tank Plants"
04-06-2015, 12:52 PM | #8 |
560
Rep 570
I asked the dealership to please pop-out the lower grille trim and take some compressed air from underneath and blow it all out. They said they'd do it w/no problem and n/c. I'll let you know how it turns out!
04-15-2015, 03:17 PM | #10 |
560
Rep 570
Results
Turns out the dealership didn't do a very good job w/removing the debris. I'll have to figure something out...
The screwdriver/tape method works for larger items, but if leaves start breaking down and building up, as they used to in my Cayman, could be a problem... |
04-16-2015, 04:42 PM | #11 |
63
Rep 274
Drives: 2007 e90 335i
guess thats one way you can get it past customs.
ED 7/7/15, PCD 9/3/15: 2015 F82 AY with Full Blk & CF Trim, 6MT, ZEC, 19" Blk, HK, 2VF, Top & Side Camera's
BMWCCA referral # 385285 |
RowanBuds1707.00 |
04-18-2015, 08:21 AM | #12 | |
976
Rep 4,000
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
04-29-2015, 05:40 PM | #13 |
1003
Rep 3,396
I don't get the whole design thing of the lower protective mesh section on the bumper, since it's large enough to allow debris build up, why make it so hard for the weekend warrior DIYer to clean it out?
Fake News 2017335.50 |
04-29-2015, 05:42 PM | #14 | |
976
Rep 4,000
05-15-2015, 05:36 PM | #15 |
368
Rep 1,175
Drives: 2015 SO/SO F80 & 135 M-Sport
So here's my solution…..
After several highway trips here in FL, I was accumulating bugs at a fast rate. Plus lots of leaves. I found these on eBay…they are 24" forceps. They fit in the lower and upper grills great, and once you have the bug or leaf between the points, you can lock it in with the self-locking portion of the handles.
I spent about 15 minutes pulling junk out tonight…just be careful not to push the tips into the delicate metal of the coolers. You can see all the stuff I pulled out. OBTW, these were about $20 with shipping.
///M3 SO/SO / MT / 19" Black Alloys / Executive Pkg. / Lighting Pkg. / Adaptive Suspension / Enhanced USB / HK / Full Front XPEL / 35 Tint / MODS: Custom painted engine cover and grill surrounds, Pedal Haus Kit, M-Performance Alcantara shifter/boot & e-brake boot, carbon e-brake handle, wrapped seat shells/rear headrests, M-Performance Spoiler with CRT Stripe.
06-20-2015, 09:40 PM | #17 |
143
Rep 1,173
This has been driving me nuts too. And then today when I went out to wash the car in the morning, I spotted a cigarette butt in there. Awesome.
12-04-2016, 12:31 PM | #18 |
Rep 1
Lint Wizard to vacuum leaves/bugs from radiator
I used a "Lint Wizard" hose attachment for my shop vac to get between front grill of the car and vacuum the leaves and bugs that accumulate in front of the radiator of my 2015 Z4 3.5is. If you don't want to order a Lint Wizard you can make your own with a small diameter plastic hose and a strong but flexible wire you can tape to the hose to act as an exoskeleton which you can twist into whatever form you need.
12-09-2016, 02:21 AM | #19 |
640
Rep 718
I use a TEKTON 24in claw. Pictured here they also have a 36in one.
Thing is dirt cheap (read: less than $10) and works perfectly. http://www.homedepot.com/p/TEKTON-36...g&gclsrc=aw.ds |
05-26-2017, 08:41 PM | #20 |
586
Rep 1,935
Leaves behind grills. How to clean them out
So I tried opening the hood but there is no way to get there. After driving for a few weeks they don't go away. How to the space between behind the grills and the radiators. I have the problem where the main radiator and lower radiator (transmission?).
Thanks in advance.
My 1st love was 2006 BMW 325i Sport + Prem 6MT but I married the 2016 M3 BSM MDCT.
05-26-2017, 11:03 PM | #21 |
Rep 18
So I have a car wash place that has air hoses available to use. I use the hose and point it at the grills and lower parts and the after a few passes, most of the leaves get blown out.
05-27-2017, 07:28 PM | #22 |
287
Rep 398
Just did this today. This clamp worked like a charm.
https://t.harborfreight.com/12-inch-....google.com%2F
2016 M4 MW/SS 6mt
Tags |
bmw m4, front grille |
