2010 2011 BMW 5 Series Forum F10 Auto Start/Stop retrofit |
12-14-2014, 09:49 AM | #1 |
Rep 10
I have a 61 plate F11 with the standard start/stop button.
Is it possible to retrofit the automatic start/stop function by fitting the newer auto start/stop button? Is the wiring already in place, and just needs coding, or is there more to it? Any advice much appreciated |
12-14-2014, 12:10 PM | #2 |
94
Rep 715
I don't think you would want it! It is so unrefined in BMWs....
BMW E60 MY2008 (LCI) 2007-2013
BMW F10 MY2013 2013-2017 BMW F20 MY2013 2013-2016 BMW F30 MY2014 2014-2015 |
12-15-2014, 11:52 AM | #3 |
47
Rep 1,074
Drives: 2014 520D SE
Garage List 2014 BMW 520D SE [0.00]
2012 Audi A7 [0.00] 2013 Fiat 500 1.2 L ... [0.00] 2008 BMW 335D SE To ... [0.00] 2012 Mercedes-Benz ... [0.00] |
Why would you want to do this?
Sure it reduces your emissions but it does nothing for your fuel consumption so you are just left out of pocket. If you are that bothered about the environment, perhaps you could trade in for an i3 |
12-15-2014, 01:52 PM | #4 |
18
Rep 186
12-16-2014, 01:38 AM | #6 |
1400
Rep 8,087
OK on manuals, horrid on autos.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
12-16-2014, 07:14 PM | #8 |
Rep 41
I find it too much trouble to use this on my manual. Put the gear into neutral, put on the handbrake, take feet off pedals..... then the lights suddenly change and it's a rush to reverse the previous! I was always under the impression that the car uses more fuel to fire up the engine instead of sat there? Unless you're sat at temp lights for 5 minutes? Maybe this was a myth from years ago?
12-17-2014, 01:37 AM | #9 |
1400
Rep 8,087
You don't need the handbrake on, you just have to be in neutral.
Ian
12-17-2014, 09:24 AM | #12 | |
6659
Rep 15,858
A European study showed "idle off" devices, (stop-start technology) for petrol engines, can save 8 - 10% fuel in urban driving, diesel about 5%. Diesels use less fuel per hour on idle, than the same size petrol engine. I'm pleased my 535i doesn't have the stop-start, as in my sort of driving it is so unusual to have a stop, it takes you by surprise in vehicles with it fitted. Then I normally switch the engine off anyway when I have a stop, say at road works, have done so for years, as leaving the engine running is a waste. HighlandPete |
12-17-2014, 09:49 AM | #13 |
1400
Rep 8,087
I didn't mind it in the manual as you could control its action - if you were pulling up to a T junction you might keep the clutch depressed and then off you go if it's clear. With the automatic it's a proper pain in the arse and I can understand the hate. I pull to a stop at the end of my road and the engine stops and then starts immediately again as I want to pull away.
I've coded mine off now.
Ian
01-11-2023, 01:13 AM | #14 | |
48
Rep 69
The short answer is no. The long answer is this. There are multiple components that lay underneath the auto start stop function, not just the button and wiring. Coding, modules, and other hardware is required in order for the engine and computers to understand what is happening with the start stop. I wish it was easier, as I assumed my grandmothers 2011 528i with the inline 6. Only 60k miles and is actually taken care of for being a grandma car lol. Sorry brotha. |
