The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > e92 320d fuel economy
      12-12-2014, 03:48 AM   #1
pinco000
pinco000's Avatar
165
Drives: F48
Hi guys, im getting around 30mpg while driving in town and some driving on roads with max 50mls.
I know I wont reach the BMWs 41mph, but was expecting a bit more when I sold my 325i which gave me 22mpg on the same roads.
What are you guys getting and what can this be down to?
cheers
      12-13-2014, 01:06 PM   #2
Kaisah
72
Drives: 340i F30 LCI
2017 340i  [0.00]
I've got a 2010 320D and I get around 43 average. Get around 50-55 with some longer journeys. 30 seems quite low, but if it's all small trips it will be.
      12-13-2014, 02:48 PM   #3
makkan00
makkan00's Avatar
886
Drives: F83 and F36
cheers
You drive in London traffic. What is your average speed next to mpg??
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      12-13-2014, 03:56 PM   #4
pinco000
pinco000's Avatar
165
Drives: F48
I have just reset the average mpg and speed. I believe though it was below 30mls. I will go for a 50 mls drive on A3 tomorrow, so I`l see what Im gonna get on a motorway. And will have a close look on the coolant temp
      12-15-2014, 03:49 AM   #5
pinco000
pinco000's Avatar
165
Drives: F48
so had a 50 mls journey yesterdsy with speeds up to 60 onA406, few stop & gos. With everything reset I got average 38.1 , with average speed 28mls.
The coolant however dint cross the 89C. It went quickly to 80C. When stationery, still didnt go above 89C. Is that ok? Or do I need a thermostat change?
      12-15-2014, 04:43 AM   #6
IanS100
IanS100's Avatar
England
136
Drives: 520d F10 LCI M Sport
89C seems ok, mine runs between 89 - 92 & I usually average around 47 mpg with 50 - 55 on the motorway, but I'm rarely in queues or heavy traffic.
50 miles, up to 60 mph, stop go & average 28 mph doesn't sound the most economical of journeys but 38 still seems a little low. Do you have a manual or auto, if it's the latter you're probably not that far out.
      12-15-2014, 05:02 AM   #7
pinco000
pinco000's Avatar
165
Drives: F48
mine is auto, rarely heavy foot.
With the temp, it runs mostly around 85C, when stationery its close to 90
      12-31-2014, 12:15 PM   #8
slidingsideways
Drives: BMW 320D MSport
I think 30 in a 320D is on the low side. I'm running a 335d and average mid 30's depending on how I drive it.
I was getting poor mpg I did a little digging about on forums and found most people say the car should run about 90c.
So I took it out for a spirited drive in sport mode I did manage to get the car to 90c but it went back down to 75-80 almost immediately. I had both thermostats in the car changed at my local garage cost me just over £200 with the antifreeze change using genuine BMW parts.
The car now runs at 90 without pushing it. My MPG and range have gone up too. last tank was 450 miles the previous tank was a little over 300. Yes its a lot of money for two thermostats but its paying off in fuel saving alone, plus I wondered if the car wasn't getting to temp if it would cause a problem with the DPF not doing a regen cycle.
You could try just changing the EGR stat first which would save you some money. My EGR stat was just over £30 at the steelers
      12-31-2014, 03:51 PM   #9
pinco000
pinco000's Avatar
165
Drives: F48
A little update from me..getting 32mpg average with speed average 22mls. Coolant not getting above 87C with light foot :
      01-01-2015, 02:48 AM   #10
Pumper
Lithuania
21
Drives: 2007 E91 320D
Check if MAF is working correctly.
      01-01-2015, 03:58 AM   #11
AWebster
16
Drives: F30 340i
I average 40 over short journeys and heavyish foot.
      01-01-2015, 05:19 AM   #12
pinco000
pinco000's Avatar
165
Drives: F48
will give it a clean tomorrow..cheers
      01-01-2015, 05:20 AM   #13
pinco000
pinco000's Avatar
165
Drives: F48
whats ur av. speed?
      01-01-2015, 05:46 AM   #14
AWebster
16
Drives: F30 340i
whats ur av. speed?
Unsure will check later and post back.
      01-01-2015, 07:53 AM   #15
Pumper
Lithuania
21
If that does not help, just disconnect it and go for a drive. If the car feels the same and you get ~the same MPGs, then your MAF is just dead (mine went up to 35-38 from 25-27).
      01-02-2015, 08:53 AM   #16
AWebster
16
Drives: F30 340i
Average speed 28 mph and average mpg 40.3, my journey is around 10minutes, so car barely even warms up.
      01-02-2015, 09:28 AM   #17
Pumper
Lithuania
21
Sound good to me. My preLCI can't get that on long journeys, let alone short ones in town with cold engine.
      01-02-2015, 04:02 PM   #18
pinco000
pinco000's Avatar
165
Drives: F48
I reckon my car is ok then. Im averaging speed of 20.8 and Im getting 32.4mpg
      01-02-2015, 04:04 PM   #19
pinco000
pinco000's Avatar
165
Drives: F48
My speed is pretty low unfortunately, therefore the low mpg. Just now I got 32.4 mpg at 20.8mph. Thanks for your reply
      01-04-2015, 04:31 PM   #20
woggledog
28
Drives: 2015 F31 320D Sport
My average speed on commutes (20 miles a day) is 17mph, and yet I'm averaging around 45 mpg
My drive down from manchester to london at christmas, with 1.5 hours in stop start traffic at vauxhall averaged me 53mpg
I think you care has issues although it sounds like the culprits (temp sensors / MAF) have been covered. My only other thought is a boost leak from somewhere. I had this on one of the two 2002 VM Golf 130PDs I had, which resulted in a 10% difference in MPG but no engine management lights
