dpf regeneration info
12-10-2014, 02:28 AM | #1 |
woman with spanners
17
Rep 122
hi
excellent video clip here well worth watching must find out now if our bmw's have the additional diesel injector in the exhaust before the dpf ( good)or if they use the regular injectors on the exhaust stroke to force diesel into the dpf ( bad) regards Katie. |
12-10-2014, 07:40 AM | #4 |
21
Rep 621
Drives: E93 M3 LCI DCT & F01 730d SE
Yes it would probably the exhaust option I would guess.
Erg bypass seems a no brainier to do. How much does it usually cost to have this done? Presumably the economy would improve and the engine life would improve dramatically too. |
12-10-2014, 08:13 AM | #5 |
woman with spanners
17
Rep 122
done a bit of searching, and yes our regeneration is enabled via releasing diesel into the dpf by injecting the diesel into the cylinders on the exhaust stroke, therefore heating the dpf to a high temp
so we have the risk of diesel contaminating the engine oil, particularly if we have interrupted regenerations on short journeys good reason to have good oil and regular changes I will not loose any sleep over it ! katie |
12-10-2014, 03:11 PM | #6 | |
6659
Rep 15,858
I've been in conversation with a local recovery guy who sorts these oil dilution issues. Worst case he had seen in a Vauxhall was draining twice the volume of oil from an engine, than the fill volume. That's 50% oil, 50% diesel. Worst case scenarios, lubrication breaking down and mechanical parts failing, or an engine running out of control, fuelled on the diesel in the sump. HighlandPete |
