12-03-2014, 01:36 PM | #1 |
16
Rep 98
MPE exhaust tips coming out unequal
Looking underneath can't see how this is possible but the tip on the drivers side is some 10-15mm longer ( tips have been removed so the difference is in the actual exhaust placement. The only reason I can see is the welded sections must be out causing it, thinking manufacturing tolerances as opposed to Fitment fault. Any thoughts Gents
Thanks Last edited by worktolivelife; 12-03-2014 at 02:04 PM.. |
12-03-2014, 02:11 PM | #3 |
16
Rep 98
Thanks! for your feedback don't feel so bothered now guess I could adjust the one tip out further to match but they stick out quite far already with both tips pushed fully on, must learn to control my OCD on a new car cheers again for the reply.
12-04-2014, 11:06 AM | #6 | |
451
Rep 4,592
12-05-2014, 12:22 PM | #7 | |
16
Rep 98
Which may be normal apparently (BMW Advised) within reasonable acceptable tolerances from manufacturer. Adjust tailpipe trims to accommodate. I did notice however if you try to adjust the trim out by too much you do get a noticeable gap where the trim slides on and the exhaust finishes which doesn't Look as OEM. An issue with cutting the original exhaust too short also, it just doesn't look " As One " The exhaust should fit into the recess lip of the trim I believe ideally |
