11-26-2014, 10:32 PM | #1 |
Rep 10
WAX/Sealant Decision
Its been a little over a month since i picked up my AW M4, so I'm thinking it's time for a sealant. My plan was to perform the normal pre-process and then finish it off with sonax pns. Then my friend told me he would lend me his finesse desire to try instead, which he swears by.
Question is, would there be any added benefit to applying the pns first letting that cure and then applying the desire or would that be a waist? If it only makes sense to use one, any recommendations on which i should use to yield the best result? All of my searches have indicated both products are well recieved. |
11-26-2014, 10:38 PM | #2 |
1903
Rep 5,678
Put CQuartz UK on the car and call it a day. Prep it, ensure the paint is clean with all other products removed and apply this. It sheds dirt like crazy, gives the car a great look and lasts for upwards of 2 years if properly maintained in my experience. Easy to apply too!!
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
11-28-2014, 09:50 AM | #3 |
1586
Rep 2,148
I'm not sure if PNS and AF Desire play nicely together. AF Desire is much better looking than PNS. I didn't test topping and did a coat of AF Desire, let it cure over night, and add a second coat. My guess is that AF Desire isn't going to last quite as long as PNS.
Both PNS and AF Desire look much better than any coating on the market. |
11-28-2014, 12:38 PM | #4 |
142
Rep 555
I have used zaino for my black cars, only 2 so far. I think it is great and repels water.
It is a little labor intensive at the first application. But after that I juat wash, spray with Z6 gloss enhancer and apply one more coat of the zaino(Z2 or Z5). Any opinions on the zaino vs others? |
11-28-2014, 04:35 PM | #5 | |
1903
Rep 5,678
11-28-2014, 05:47 PM | #6 | |
Gone Fishin’
7316
Rep 12,125
11-28-2014, 08:42 PM | #7 |
1903
Rep 5,678
I haven't tried it yet so no meaningful opinion.
11-29-2014, 03:10 PM | #8 |
Rep 10
Ok so i'm going to give the desire a try ( esp since it's free to use for a trial run). I looked over the car a few times and am not seeing any real imperfections, could be the AW hiding it. But im flirting with wash, autoscrub, right to sf4500 (least abrasive pad) then desire. I know 4500 is a finisher, but im not seeing the need for anything else other then some added gloss before wax. I know this isnt the most common formula, but given the condition do you think ill get a decent result?
11-29-2014, 08:58 PM | #9 | |
1586
Rep 2,148
12-03-2014, 10:15 PM | #10 | |
1860
Rep 2,104
Also, u probly just forgot to say this, but might want to iron-x before u autoscrub. Less work, just in case. I think I'm gonna give Opt Gloss Coat a try. Was a toss up between that or CQUK, but I think the OGC will be easier to apply. I'm willing to sacrifice a little looks for functionality/longevity. Btw, Money, how often did u clean the auto scrub pad when u did the GT3, and what did u clean it with? This will be the first time I'm using it. Also, how often did u change or clean pads when you did the jeweling? Thnx. |
12-05-2014, 08:46 PM | #11 | |
1586
Rep 2,148
I usually brush the pad often and will typically use two 6.5 inch pads, one 5 inch on the Duetto, and a 4" on the small Griot's. It's more important to reactivate a microfiber pad than brushing a foam one. I just brush it with a pad brush every so often out of habit. |
12-06-2014, 10:45 AM | #12 |
82
Rep 280
I opt-coated my last car (435i) and it's worth it imho. It's much easier to keep the car clean (I also had MG so that was important!) and if you also coat the rims that makes brake dust removal much easier. Also gives you some protection from rock chips. Just make sure it's applied correctly and has time to fully dry/cure (at least 12 hours from application I think). Cheers
12-07-2014, 12:10 AM | #13 | |
1860
Rep 2,104
12-07-2014, 12:15 AM | #14 |
346
Rep 1,656
What are you guys talking about? Anyone in So Cal wanna detail my AW?
I have a brand new bottle of Menzerma [sp?] from last year when I had my GTR. Is that stuff any good? Can anyone use it here? |
12-07-2014, 02:08 AM | #15 |
1343
Rep 3,342
Paint correction and care! The best subject!
I am way out of practice, for sure. Haven't detailed in a while due to work.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
12-07-2014, 05:54 AM | #16 |
1586
Rep 2,148
12-07-2014, 12:16 PM | #17 | |
56
Rep 198
For best jeweling results I suggest the butter soft gold jeweling pads. They're the softest jeweling foam pads on the market. http://www.autogeek.net/gold-da-pad.html All I polish is black.. Never gone back to Menzerna since. |
01-16-2015, 01:05 PM | #18 |
137
Rep 372
I'm local...wanna help me for free I am so bad at this stuff it's crazy. The only thing I am good at is staying away from mobile gas station car washes and BMW complimentary car washes.
M4 - White Sex Panther
E46 M3 - Pablo the cocaine smuggling donkey |
01-16-2015, 08:00 PM | #20 |
1586
Rep 2,148
Shoot me a PM if you want to come up and dial your paint in. I'd be happy to help. Are you going to Ultimate Auto Cars and Coffee tomorrow? I'll be there.
01-17-2015, 10:01 AM | #21 |
137
Rep 372
That is really kind of you for sure. Unfortunately, I am in testing mode all weekend for launch of a new version of a site I manage, so no fun car activities for me. I will PM you later next week when I slow down a bit.
01-17-2015, 07:27 PM | #22 |
BimmerPost Supporting Vendor
1991
Rep 6,916
you can always try both, get a couple parts of the car in Desire and in PNS and try it out.
after PNS is cured you can top it if you like, I have heard some waxes will decrease the durability of PNS. |
