New here; best begining suspension mods
11-25-2014, 11:40 AM | #1 |
Rep 37
I want to firm up the handling of my 2011 e92 coupe. Car has 41k miles and its time to start upgrading. What are a few basic things I can do to make the car more firm and direct? I simply want to improve the handling and give it a more sporty feel in the twisties.
11-25-2014, 12:08 PM | #2 | |
1234
Rep 3,778
Drives: '11 328i '19 M6
Changing the front control arms to M3 parts and replacing the bushings in the LFCAs with a Bimmerworld spherical bearing, or equivalent, will further tighten up the steering making it more precise and responsive. At that point rear subframe bushings would be called for as their limitations would become more obvious. Personally I recommend solid bushings but ymmv. You might run into e-diff limitations at this point so an LSD would be a useful addition but a good one is really expensive. And diff bushings and mounts wouldn't be a bad idea at this point either. Again, I recommend solid ones but again ymmv. M3 rear upper links and toe arms are an option eventually but not really called for unless you want to go toward a fully rigid link suspension in which case you'll need to have welded in the Bimmerworld inner swingarm spherical bearings, or equivalent. Then the dampers and springs will definitely be the limiting factor again. It all depends on how much you're willing to sacrifice to improve your DD, I think.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
11-25-2014, 03:02 PM | #3 |
28
Rep 583
Upgraded front and rear anti sway bars. Many companies offer kits or you can purchase them separately. From what I understand the front makes the biggest difference and without a LSD the rear can actually become detrimental.
Either way, these are relatively easy to install ( the front is anyway) and do not require an alignment afterward so its a great upgrade IMHO.
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
11-25-2014, 03:33 PM | #4 |
136
Rep 1,192
Drives: 2011 335i MT
An LSD is not really that expensive. Several vendors are offering LSDs in the $1300 ballpark. Considering what people spend on a new set of wheels and cosmetic upgrades, the LSD is not that expensive. Plus, when you consider that the LSD helps you get all of the torque on the ground, instead of having your wheels spin uselessly, its an upgrade where the results are immediate and noticeable.
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
11-25-2014, 04:25 PM | #5 | |
1234
Rep 3,778
11-25-2014, 10:39 PM | #7 | |
714
Rep 3,251
With welded gear, prepare to shell out close to $3000. An alignment with more neg camber up front and stiffer front sway is cheapest and most effective upgrade if you don't track your car.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
11-26-2014, 12:59 PM | #8 | |
136
Rep 1,192
When I first got the car, even before JB4, I noticed the tires struggling to get traction, especially when cornering or accelerating. The LSD cures that problem. I don't go to the track (nor do I have plans to). The LSD makes a big difference in terms of traction in day to day traffic. I think everyone has provided good suggestions, such as neg camber, front sway bar, etc. I just think LSD should be included in the suggestions. For $2k, an LSD is excellent bang for the buck IMO.
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 Last edited by snaimpally; 11-26-2014 at 01:05 PM.. |
11-26-2014, 02:02 PM | #9 |
1234
Rep 3,778
An anti-roll bar couples the left and right wheel carriers together with a torsional spring, the stiffer the bar the more tightly coupled the two sides' spring rates will be under lateral weight transfer, so ride quality will be unchanged under straight line conditions but cornering will be flatter.
11-26-2014, 02:05 PM | #10 |
173
Rep 1,117
Drives: 2010 E90 328i 6MT ZSP BSM
Thanks justpete. I understand but what about going through a pothole, for example? The coupling of the two front wheels would cause the impact from one side to be partially transferred to the other side. Would that cause a noticeable impact on ride comfort?
11-26-2014, 02:47 PM | #11 | |
1234
Rep 3,778
Because the bar tends to progressively resist the vertical movement of the wheel the car would tend to rock a bit more toward the side where the chuckhole is but it's not like having a rigid axle but somewhat more so than with a less stiff bar. And the dampers' rebound and compression settings would tend to mitigate the shock, within reason. Oversimplified as this doesn't take into account deformation of the tire or that of the one on the level side being loaded by the force of the bar applied through from the one following the chuckhole. If you're looking for ride quality over handling then a stiffer anti-roll bar is probably not a good thing. It's pretty difficult to get both without an adaptive suspension.
11-26-2014, 07:58 PM | #13 |
1234
Rep 3,778
The MagneRide system in the CTS-V variants and, I think, the new Camaro would be cool. Man do they ever work on the track, it's amazing to watch a CTS-V wagon scream through corners on pretty much any line at all. And then they're just fine on the street. What a deal. Wonder how long it'll be before it's common across most cars, if ever.
12-01-2014, 06:34 PM | #15 | |
24
Rep 209
Drives: Z4M roadster
1. Whiteline rear subframe inserts, to control the errant rear end 2. M3 front control arms/tension struts to add some negative camber to the front 3. M3 front ARB 4. Bilstein B12 kit or Koni Sports with matching springs (Eibach) Then, if you want to go to the next level, 5. LSD Enjoy - search function, or Google is your friend.......
2006 Z4M roadster. Interlagos Blue, black extended leather with carbon trim. Apex EC7 8.5/9.5 x 18 rims, Strong Strut brace, KW V3s with RE rear shock mounts, Vibra Tech and Rogue engine/transmission mounts, Stromung exhaust, CDV delete.
