F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Brake Noise?
ARMA SPEED
      11-19-2014, 05:23 AM   #1
963mw
BMW Fanatic
963mw's Avatar
331
Drives: M2
Brake Noise?
Hello everyone, I got my 435i X-Drive around 5 months ago and it has been one hell of a ride, perfect in every sense. However starting 3 months ago, my brakes would start to squeal after a decent 15-20 minute drive, when applying them at low speeds (stopping for a traffic light, braking while going down a small incline) My dealer has my 1st car check up scheduled at 10,000 km. My car just reached 4000 km. Should I be concerned about the brakes and the noise they are producing or is it normal? I live in Beirut (coastal city) so could it be just the humidity or is something more serious in line? The reason I ask is because my 528i doesn't produce any braking noise whatsoever and it is put under daily intensive use.
Thanks in advance
      11-22-2014, 04:08 AM   #2
fotis_k
Greece
Drives: F32 428i
Probably it's nothing ,but would be a good idea to be checked just for piece of mind!
      11-22-2014, 08:07 AM   #3
Professor///M
Professor///M's Avatar
No_Country
819
Drives: 2022 M3, 2022 X5 40i;
Do you have the M sport brakes?
      11-22-2014, 12:34 PM   #4
963mw
BMW Fanatic
963mw's Avatar
331
Drives: M2
Nope, Standard brakes
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      12-02-2014, 11:43 AM   #5
Yehia osman
Egypt
Drives: 320i F30
Brakes were hot you drove through water , damaged discs i guess , is it just the noise or at higher speeds you feel the steering wheel vibrate when braking ?
      12-02-2014, 11:49 AM   #6
963mw
BMW Fanatic
963mw's Avatar
331
Drives: M2
None of the above, only squealing/squeaking at extremely low speeds while braking.
      12-02-2014, 11:57 AM   #7
Yehia osman
Egypt
Drives: 320i F30
I'd recommend checking it with the dealer . To stay safe and prevent developing of the problem .
      01-07-2015, 08:26 PM   #8
casualDIYer
446
Drives: 340i xDrive M Sport
Welcome to the world of BMW squealy brakes. I suffered a similar problem when brakes were cold. After multiple and lame dealer excuses I got fed up and switched to Akebono brake pads. Totally silent.
      01-07-2015, 09:37 PM   #9
Axman85
77
Drives: 335i x-Drive M-Sport Min. Grey
Mine only squeal with my snow tires and rims. When my oem's are mounted no noise at all. Reading another thread about this there was a consensus that the torque applied to the lug nuts wasn't set right and causing the squeal. That may the the case as my oem's should be at 120 lbs and the other rims at 130. The tire shop doing the swap set them at BMW spec of 120. Haven't tested by tightening the winters as I would rather have squeal vs potential rotor damage from and over tightened wheel. Perhaps you should check the torque applied to your wheels.
      01-08-2015, 01:40 AM   #10
dreamspeed
dreamspeed's Avatar
262
Drives: 6MT
If you don't notice anything else abnormal and the car stops good then it's just normal brake squealing. Brake squeal comes and goes pretty often based on all sorts of variables.
If it really bothers you you can take it to the dealer and ask them to look at it. Most likely they will put some dampening paste and/or replace the brake pad shim
      01-08-2015, 01:42 AM   #11
dreamspeed
dreamspeed's Avatar
262
Drives: 6MT
Is 120 the official torque specs? That seems high for alloy wheels
      01-08-2015, 08:38 AM   #12
Axman85
77
Sorry, should have said 120N-m which is around 88 or so ft-lbs.
      03-04-2015, 01:39 PM   #13
platnumdesi01
52
Drives: 2009 335i Coupe
I have a m-sport and it squeals here and there. Dealership said its normal. What also helped was getting a car wash, the brake dust could be causing it as well.
Tags
brakes, squeal
f30post
