Intermittent RHS Front Indicator Failure
11-15-2014, 11:44 AM | #1 |
Rep 17
Hello all,
First post to ask a question, I have a 57 Plate E90 330d and have noticed an intermittent fault with the RHS front indicator in the headlamp. 2 weeks ago I noticed the bulb was gone and proceeded to pickup some bulbs from Halfords and change it, everything was fine and it worked no problems. About 4 days later I get an IDrive message reporting the bulb has failed, quickly swear about cheap Halfords bulbs and swap it for the other in the pack, all is good once again. Since I've checked the bulb however it is actually fine and the current bulb has intermittently been reported as failed on the IDrive only for the indicator to start working when I get back into the car later in the day. Has anyone experienced anything similar or this before? Just looking for a bit of direction as to what to pursue, I have a coding cable and software so will check fault codes later this weekend. |
