Is my oil filter housing gasket leaking?
10-18-2014, 10:24 AM | #1 |
38
Rep 627
Looks like I have a oil filter housing leak but I think my valve cover gasket is leaking also or maybe somewhere in the Eccentric shaft sensor.
Here are some pictures I took. I'm planning to get the filter changed out but it looks like there's should oil leak around valve cover also. What you guys think? |
10-18-2014, 10:59 AM | #2 |
129
Rep 1,052
Yes and you should get them all fixed.
There are DIY's for all of those available in these forums. That being said I was able to get mine done under CPO thankfully. Also, don't forget to clean up those areas after or while you fix them
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
10-18-2014, 11:30 AM | #3 |
Fuck it dude, let's go bowling.
888
Rep 2,480
Yes, and yes. So is your oil pan
Seriously, an '07 will have all three of those leaks if not already addressed.
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
10-18-2014, 01:22 PM | #4 |
38
Rep 627
so the oil filter housing gasket and valve cover gasket?
I did some research and I might have to possible replace the valve cover also if it's split or MIGHT later on. Not sure if I can re-use the bolts or not. I did replace the spark plugs last year but I don't recall the color of the valve cover bolts. Anyways thanks for confirmation guys. Just wanted to double check and make sure. I'll probably get the oil cleaned up after I change the gaskets. I'm just thinking of bring it to a detailer to get my engine cleaned. I'm not really sure or confident in cleaning the oil off without harming the engine when the valve cover off. I usually do my own oil change and brakes but I think I'm just going to get a shop or prostock3 to do it since I'm not confident working on the internal part of the engine. I've done spark plugs, serpentine belt, pulleys, tensioner, trans fluid, diff fluid but for some reason I always weary of touch any sensors or internal part of the engine. |
10-18-2014, 06:17 PM | #6 |
34
Rep 142
I had similar issue and it was only vcg, so if your oil filter housing is in oil, not always mean it has a leak also. It's kind of unrelated jobs: vcg and oil filter housing. First do vcg and clean the engine, then you will know if filter housing leaking as well.
10-18-2014, 06:53 PM | #7 |
158
Rep 3,158
The sneaky thing about the oil filter houing gasket is that it could be leaking internally. That is, between the oil and coolant passages.
I had mine done around 60k miles without it showing any leaks...when the tech opened it up, he found the internal passages on the verge of cross contaminating. |
10-19-2014, 02:39 PM | #9 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
yeah the vcg bolts on an '07 should be re-useable.
for the oil filter housing gasket, it's a manageable DIY and there's a good one on the forum. Read the comments as some people ran into issues not experienced by the DIY OP. There are 3 star bolts to break, two of them are somewhat difficult to get to, and if you use a hex wrench there is a risk of stripping. I bought a star ratchet to fit the bolts after stripping the head of one of them. Fortunately the star ratchet provided enough bite to get it out. Otherwise, it's a pretty cheap DIY. You might do the DIY on the ofh first, clean everything up around the valve cover and then see if you valve cover gets messed up again. It would be a shame to do the VCG if the OFH is the cause of the grime. |
10-19-2014, 03:38 PM | #10 |
38
Rep 627
I was planning to just get it done at a local shop since it was only $100. I went through that DIY thread and it seems like members were having problems and I'm already not confident enough on doing that. I'll order the parts and see later on.
I was planning to the the oil filter housing gasket first but I think I'll just order both parts when I'm in the US since they aren't too expensive Last edited by Zero_09; 10-19-2014 at 07:32 PM.. |
10-19-2014, 07:28 PM | #11 |
129
Rep 1,052
Check the valve cover for hairline cracks too. Mine had one and so my leak continued after my VCG was done.
10-19-2014, 08:16 PM | #12 |
888
Rep 2,480
If it were me, and I were replacing the VCG, I'd replace the VC at the same time. They are prone to hairline cracks over time. It's a job you don't want to do twice. The new VC will come with all new bolts, a new gasket and a new PCV - all for around $350 at GETBMWPARTS. Also, while you're at it, replace the PCV vent hose for around $25.
10-19-2014, 08:23 PM | #13 | |
Gateropode
329
Rep 2,848
10-19-2014, 11:39 PM | #15 |
138
Rep 2,731
no idea if your car will have the brittle vent hose going to the valve cover from the oil separator, but you may want to order one of those too since it will likely crack.
10-21-2014, 05:58 PM | #17 |
38
Rep 627
Just came back from the coin wash and power wash the engine bay.
Used ZEP heavy duty citrus degreaser, Optimum power clean 3:1, and Gunk engine degreaser and got most of the oil off. I was a bit weary spraying the degreasers in front since they belt was sitting right there. Would if be harmful if some of the oil I cleaned off get on the serpentine belt? Do you guys usually cover the belt also when spraying done the engine to clean up oil leaks? |
10-21-2014, 08:21 PM | #19 |
12
Rep 85
Today we worked to remove the valve cover gasket on our 2006 325xi (N52 engine). A month or so ago, I had the water pump fail, and so decided to replace that and the thermostat. While in there doing the WP/TS, I noticed oil seepage all around the passenger (right) side of engine. I figured that must be where the oil has been going! It seems that every 6 months or so I get the oil low indicator.
After reading on the forums here and there, it seemed to me what I had was a leaking Valve Cover Gasket. So, I ordered up the new gaskets and screws (mine is the model with the aluminum screws and cover - no plastic or steel). Today we spent a couple hours getting to the point where the valve cover is ready to have its bolts loosened. I work my way from the front left of the cover, to the front right. The fifth screw I am going to loosen (front-most on the passenger (right) side) is just sitting there, broken!!! I pick it up and sure enough it's busted in half! And, as I look, the oil seepage is coming from the area around this particular bolt! FML! Fortunately, I was able to use an awl to reach into the bolt hole and spin the busted tail piece out with little or no effort, no easy-out or drilling necessary WHEW!! At this point, we decide to go ahead and finish the job of replacing the valve cover gasket and other items - a couple more gaskets, new spark plugs. We will continue tomorrow, putting it all back together. I originally had a dealer change my oil, but have been doing it myself lately. And I think I recall the oil light coming on after about 6-12 months in the past. So I think, but can't be sure, this may have been leaking from the time I bought it (which was just a few months out of warranty). It is possible this is why the guy sold it to me. He was anal-retentive about oil leaks, and I suspect he might have wanted to get rid of it rather than pay dealer prices to have the issue repaired. I'll never know. |
10-22-2014, 06:45 AM | #20 | ||
38
Rep 627
There has been two times I've had to top up the oil with a 1L bottle in the past two years. It seems to happen randomly though because I check the oil level pretty often since there's no dip stick it's pretty easy. Last edited by Zero_09; 10-22-2014 at 06:52 AM.. |
10-22-2014, 08:12 AM | #21 | ||
12
Rep 85
Now I am thinking I should replace my coils, although getting to them isn't near as much work as getting the valve cover itself off!! |
10-22-2014, 10:22 PM | #22 |
12
Rep 85
I decided to wait on the ignition coils. This was mostly due to the fact that two of the nearby dealers did not have the parts in stock. Well, one of the dealers had four units, I need six if I'm going to do them all. So, I figured, if I have to wait for the parts, I may as well wait until one goes bad and then order the parts from Tischer. So far, Tischer is the best price, including shipping.
