10-13-2014, 04:25 PM | #1 |
590
Rep 5,396
WORK emotion CR will fit in 19 inch, thoughts?
Looks like these have appropriate offsets for the f8x m3. They will allow you to run 275/30 and 295/30 with proper fitment. Anyone like these? Think they will look good? Im considering it......
Front 19x9.5 et22 (+12 over stock) Rear 19x10.5 et32 (+13 over stock) http://www.workwheelsusa.com/media/w...LT_2013_v1.pdf Some good pics here http://europeanautosource.com/work-e...wheel-set.html
10-13-2014, 06:58 PM | #2 |
471
Rep 2,991
They look like they will fit and I dig the concavity. I really like these wheels, I had a set of +22/+22 9.5/10.5 for my E92.
10.5 +32 means that the edge of the wheel will be +6.35mm closer out for the additional width, and +8 for the reduction in offset. That means that you're 14.35mm out, or like running a 15mm spacer on the stock wheel. I suspect a 295 will still fit but it will be pretty close. I know people run +18mm spacers on the rear. Then again, I know that an 19x11 et40mm with a 295 leaves some roomwhich would be 12.7mm closer. You're less than 2mm further, so they should fit. That's my napkin math and I'm sticking to it. Anyone try yet? |
10-13-2014, 08:45 PM | #3 |
590
Rep 5,396
Well, I think I will hold off because I talked to vorsteiner and they are releasing the new vff 103 in late November in 9.5/10.5 width specifically for the f8x.
They look pretty sick to me. Price will be 2200 http://n4sm.com/vorsteiner-wheels-vff103 Fyi agree on your offset calculation |
10-13-2014, 08:47 PM | #4 |
346
Rep 1,656
10-14-2014, 12:12 AM | #5 |
1002
Rep 3,052
11 in the rear with a 34-36 offset works with a 295 PSS tires.
11.5 works with a 42-44 in the rear with a 305
2022 RAM TRX
2021 Ford Bronco 2022 BMW M3 |
