can i code multiple modules at once?
10-08-2014, 09:18 AM | #1 |
162
Rep 2,399
So i done some coding today
Such as done some coding in the KOMBI module And then done some coding in the DWAI Module But what i done was once coding finished on KOMBI module i shut down NCS properly and disconnect Cable etc and take key out. then start car back up and if KOMBI module coded ok i then plug back in all again and code with DWAI module If i go through normal procedure in NCS and let the coding end in KOMBI Can i just process a new ECU and start coding on the DWAI module without shutting down in between and both will work on what ive coded when i disconnect the car? |
