Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      10-02-2014, 01:45 PM   #1
M4NACE
M4NACE's Avatar
28
Drives: F82 M4
255/35/19 square set up snow tires on Stock 19s
Hi Guys,
According to Tirerack, the Rim Range for 255/35s are 8.5-10
Our stock 19s are:
19x9 (front)
19x10 (rear)
Is it safe to assume then, we can run squares with our stocks?
      10-02-2014, 03:03 PM   #2
BigMacSmallFries
123
Drives: '19 M5C 911 Turbo F430 GT3 RS
Originally Posted by M4NACE View Post
Hi Guys,
Our stock 19s are:
19x9 (front)
19x10 (rear)
Yes, already bought these exact tires. Mounting them on the M359s (same widths). The stretch at the back will look a bit silly but will be totally safe.
      10-02-2014, 03:41 PM   #3
Onetime237
10
Drives: 335
I heard the stagger is part of the making the traction control system effective...that true?
      10-02-2014, 04:16 PM   #4
JoeFromPA
1795
Drives: '15 AW M3 6MT Stripper
BMW sells the winter setup non-staggered in 18" size as their recommended 18" setup, so no.
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
      10-02-2014, 06:10 PM   #5
Onetime237
10
Drives: 335
Tire rack is so random
      10-02-2014, 06:23 PM   #6
minus9
Grand Poobah
Drives: F80 M3
Having the tires the same width really makes the most sense with the wheels the same as well. Are you going to rotate the 10in ones to the front at some point?
If you keep mounting and unmounting them to rotate, you're going to weaken and harm the bead.
      10-02-2014, 06:24 PM   #7
M4NACE
M4NACE's Avatar
28
Drives: F82 M4
i might rotate them every 2 years or so. (I keep my cars for 6-7 years max) I don't expect i would rotate them more than that.
f80post
