M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      09-14-2014, 01:12 PM   #1
wonderkid23
Drives: 2014 BMW M5
coolant level low...need help please
I was on the mountain over the weekend and had coolant low alert on the dash appear. I purchased pristine coolant and topped it up. However, i still have a warning sign on and it deos not go away. I checked th level, it is still between min. and max. Today is sunday and dealer service is closed. Can I drive and go to the dealer tomorrow? I still have to drive a couple of 100 miles to go home.
      09-14-2014, 02:10 PM   #2
drbru
99
Drives: f10 m5
as long as your engine doesn't get a chance to really heat up (i.e. stuck in traffic) it should be fine, especially if those miles can be done on the motorway
      09-14-2014, 02:53 PM   #3
wonderkid23
Drives: 2014 BMW M5
Thanks....I made 75%of trip without any trouble...about 30 more miles to go...stopped for lunch break...I will go to the dealer tomorrow morning.
      09-14-2014, 03:19 PM   #4
///SAL
///SAL's Avatar
36
Drives: 2014 ///M5 ZCP
Reset the dash, read the manual
      09-14-2014, 03:27 PM   #5
bobblehead
bobblehead's Avatar
256
Drives: warp speed
do you have a leak ?
I had a leak thru the coolant tubings (right underneath the plastic engine cover). The factory clamps are not tight enough.
Open the hood and check to see any greenish coolant that had been dried off.
      02-23-2015, 02:16 PM   #6
Ziff73
Drives: M5
Had a low coolant warning the other day as well. Checked under the plastic cover and saw what looked like dried coolant on the engine.
Dealership said they did the campaign to replace the heat mats back in December. Maybe they didn't replace the clamps as well.
I topped off with pentofrost nf and water. Assume this is a slow leak? Dealer appointment next week.
Anyway to clean the engine?
Thx
      02-27-2015, 10:31 AM   #7
Ziff73
Drives: M5
Ok. So it was a leak. Any concern with leaked dried coolant on the engine? Can't see how deep into the engine the coolant went.
      03-16-2015, 12:22 PM   #8
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
I believe you checked the intercooler fluid level , not the same as the primary engine coolant level detector which is electronic .
Search this Thread:
Advanced Search
m5post
