09-10-2014, 05:25 PM | #1 |
269
Rep 1,282
Square Setup for Snows on the F8X
So, here is my dialogue with the TireRack about this:
"Question: It would be great to see a Square 18" setup for this car, with 255's all around. Please see what you can do on this." "Hello Dave, Thank you for your inquiry, I am happy to assist you. I was just having this discussion with our engineers on this for another customer. We have found that due to the .6" stagger BMW has put on this car we can't do a square set up. We are having a heck of a time with a winter set up for this car. I wish I had better news but that's where we are at. Please let me know if you need anything else." I've used the Turner calculator - very cool tool on their wheel site - and he's right. It likely can't be done.
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune Alpina B8, zero performance mods |
09-10-2014, 07:01 PM | #2 |
1903
Rep 5,678
I have a square 19" setup and Avant Garde has guaranteed the fitment (I have not put them on yet as I'm waiting for tires but was guaranteed they would fit and the offsets would work). 19x8.5 ET15 running 255/35-19 tires... it will be pushed out 14mm further in the front and 15mm in the rear. I've measured and there should be lots of room without sticking out (no different than people running a 15mm spacer on OEM wheels).
I'm not sure why the staggered setup matters on the F8X so much to Tire Rack? The E92 M3 was staggered as well and lots of people ran square set ups. Tire Rack's issue is they don't have a wheel... yet... that clears the brakes and has the right width and offset to work. It isn't that they don't exist... it is Tire Rack doesn't have it P.S. Try this calculator, it's my favourite ... http://www.rimsntires.com/specspro.jsp
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 Last edited by gthal; 09-10-2014 at 07:20 PM.. |
09-10-2014, 09:18 PM | #3 |
233
Rep 1,177
I am interested in 18" winter setup as well. Doesn't have to be square. Hopefully they'll have some 18" wheels for our cars soon.
Current: 2022 X3M Comp
Previous: 2020 X4M Comp | 1982 E24 633CSi | 2016 F82 M4 | 2015 F80 M3 | 2014 F30 335xi | 2013 F30 335xi | 2010 E92 335xi |
09-10-2014, 10:02 PM | #4 | |
123
Rep 353
I don't know anyone who has used square 265 winter wheels for a RWD car of this weight. Unfortunately you need wheels the same width. I also don't think it would be a problem using wheels that are 8.5 x 9.5 and running that 255 setup you would like. A large majority of 18" wheels can't be mounted on 15" rotors. Not even bothering experimenting with that. |
09-11-2014, 02:44 PM | #5 |
123
Rep 353
Sorting out my decision here.... I doubt more than one or two options will be out in the next couple of months for our cars.
What makes more sense? I'm traveling quite a bit in the winter these next few years including trips for snowboarding with roads that are not plowed well so I decided the LM60 will be the best performance tire for moderate snow, whereas the PA4s/LM32 are great for light snow. Does it make more sense to get a 265/35/19 square set up with 9x10 wheels or get 255 fronts 265 rears? I mean, I doubt an extra 10mm of width at the front will make much of a difference and it would mean I'd be able to rotate the front and rears half way through their life cycle. However, there is an inch difference in the wheel width and don't know if stretched winter tires really harm the handling or not. Any guidance would be appreciated. |
09-11-2014, 06:22 PM | #6 | |
1903
Rep 5,678
I'm a big fan of square winter setups because of the ability to rotate tires... but I would try to find a 255 setup on a narrower wheel. But, as you say, 10mm probably doesn't make THAT much difference.
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
09-11-2014, 08:34 PM | #7 |
General
21115
Rep 20,741
Drives: 2021 911 turbo
I intend to use my E9X 270M square winter wheel set on my M4.
The offset front and rear should put them almost flush with the stock 19" (front will stick out by 4mm and rear by 5mm). I hope it will work out. Last edited by CanAutM3; 09-11-2014 at 08:44 PM.. |
09-11-2014, 09:00 PM | #8 | ||
General
21115
Rep 20,741
09-11-2014, 09:07 PM | #9 | |
1903
Rep 5,678
The PA4 is clearly a better dry pavement tire than the LM-60. However, it's predecessor (PA3) was scary dangerous in wet snow and ice. I sold mine after one month of ownership. Michelin says the PA4 is better by a small margin in these conditions... still less than great IMO. The LM-60 was WAY better in bad conditions... and worse on dry roads. I think it comes down to how you intend to use them and what your climate is like. I agree that Nokians are the way to go... hence why I have Hakapelitta R2s coming next week
09-11-2014, 09:11 PM | #10 | |
General
21115
Rep 20,741
They did drive and test them in the snow. The PA4 an LM-60 are pretty much on par in the snowy conditions. But the PA4 has the LM-60 beat on the dry and in the wet, which makes it the best all around tire in this test . |
09-11-2014, 09:20 PM | #11 | |
1903
Rep 5,678
Maybe the PA4 improved enough to put them on a level basis? Michelin says something like a 10% improvement over the PA3 and, based on my experience, that would still put it far behind the LM-60 in a snow storm I also believe that the climate and type of snow matters. Dry, fluffy stuff and the PA3 was OK. Wet, heavy and icy snow and they were useless. My view is Tire Rack doesn't test their tires in more severe conditions but I could be wrong. Don't get me wrong... in the right conditions the PA3 was great. I just couldn't rely on it if the weather turned and Michelin would have had to make HUGE improvements to make it good enough IMO.
09-12-2014, 04:31 PM | #12 |
123
Rep 353
FYI, tirerack comparison tests are done on packed snow and ice. What gthal is saying is correct. You put 10cm of fresh powder on the ground and all of a sudden you're not going anywhere with a slight incline.
Have been running wintersport 3Ds on my E9x M3s for 3 years now. There's all these amazing reviews about them. When there is 10+cm of snow on the ground, the first day I simply can't go anywhere until the other cars pack the snow down for me. The PA4/4D/Sottozeros are not the greatest. I'm trying to find LM60s as they seem to be the only cross between a true snow tire and performance winter. There doesn't seem to be any other choice out there and the wheels are discounted which stinks. As one pointed out, when it is below zero or wet with no snow, LM60s are nowhere near as good as the PA4s. But some of us don't have a choice. Last edited by BigMacSmallFries; 09-12-2014 at 04:38 PM.. |
09-19-2014, 08:10 AM | #13 |
314
Rep 2,448
Ran lm60 265 square set up past winter which had to be one of the worst here in GTA. The tires did a much better job than my previous wintersport 3D and PA3.
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 |
09-19-2014, 09:43 AM | #14 |
1903
Rep 5,678
Just picked up my winter wheels and mounted winter tires. I'll post pics and details later.
09-19-2014, 02:17 PM | #15 |
28
Rep 118
interested in seeing those pics. I want to get a set of M510s for my summers. would love to see it on your car. I'm tempted to run winters on stock rims and run 20" 510s or 580s in summer. not sure if that's a good idea. haha
09-19-2014, 03:13 PM | #16 |
30
Rep 217
Snow Tire Set Up
I have purchased 4 wheels (2-19x9.5 & 2-19x8.5) Advanti Drago MGDC & 4 tires (2-275/35ZR-19 & 2 255/35ZR-19) Pirelli Winter Sottozero Serie II 270 XL from the Tire Rack for my M4.
I did not worry about the "Run Flat" deal, if I can't plug it with a trunk kit or call a tow platform...I'll be late for my destination..LOL Good reviews on this Pirelli tire.
BMW Owner 2-3 & 4 Wheels
09-19-2014, 05:09 PM | #18 |
1903
Rep 5,678
Here is my set up... http://f80.bimmerpost.com/forums/sho....php?t=1037506
