Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Question about suspension E90
      06-03-2005, 03:38 AM   #1
Wormit
Drives: BMW 320 E90
Hi there
This is my first post here, my english is a little bit rubbish but I am from Sweden to that's why
I will get my BMW 325 - E90 or I pick it up in end of June.
I have all the Dynamic/Sport kit on it, but I want to lower it...
The wheels are standard 18" from BMW:Front: 18x8 +34 offset with 225/40/18 <> Rear: 18x8.5 +37 offset 255/35/18.
I have looked at H&R suspension in following dimensions 35 and 50mm, I would prefear 50mm if it's fit and work.
So my question is, is the 50mm suspension-kit from H&R going to work?
Please try to help me so I can order the kit!
Thank's in advance
//Wormit
      06-03-2005, 05:44 AM   #2
Mark
Administrator
Mark's Avatar
6731
Drives: 1M
yep, it will fit and work
      06-03-2005, 05:55 AM   #3
Wormit
Drives: BMW 320 E90
Perfect!
Do you have this kit on the car on the picture?
Kindest regards
Wormit
      06-03-2005, 12:24 PM   #4
weytie
77
Drives: BMW M4 F82 Competition
I have allready my E90, with sport suspension. But i'm looking to lower it a bit.
My only alternative for the moment is springs from H&R , because I want to lower him about 35mm, so i'll need to take the -50mm springs ( 35 + 15 (Oem sport suspension)
But i'm a bit afraid for the ride quality, running on 19".
If you want to have a minimum of comfort loose, you need to pick springs of eibach (pro-kit). But for the moment they provide only 30 mm springs and the other ones are 'in preparation'
Don't knwo what to do
Stijn
      06-13-2005, 02:40 AM   #5
apex188
Drives: E90 330i
does H&R or Eibach make any springs for the E90 that are a bit less than 50mm? or even 35mm? I want a good handling car but I dont want it to be too low as the front body piece is already quite low to the ground.
Any suggestions?
thanks
      06-13-2005, 06:56 AM   #6
Jason
Administrator
Jason's Avatar
40855
Drives: F80 M3
Any suggestions?
thanks
Yes. Check out the aftermarket suspension sticky thread at the top of this forum (http://www.e90post.com/forums/showthread.php?t=613). 35mm is about 1.38" and you'll see that there are a few options that drop the car 1.2"
      06-26-2005, 10:46 PM   #7
apex188
Drives: E90 330i
So Eibach, H&R, Hartage and KW all make springs for the E90.
Does anyone have suggestions as to which are better? I"ve been reading the Eibach is probably the best ride as the pro-kits are progressive springs, which also a bit easier on the stock shocks. Is this true?
I don't know anything about KW or Hartage springs, so I 'm deciding between Eibach and H&R.
Any suggestions?
thanks
      06-26-2005, 10:51 PM   #8
Mark
Administrator
Mark's Avatar
6731
Drives: 1M
Any suggestions?
thanks
exactly true If you want a better ride and longer lasting OEM shocks, eibach is the better choice. If you want stiffer/better handling go with H&R and match it with stiffer shocks in the future.
