09-06-2014, 04:08 PM | #1 |
Rep 10
What options are needed for anti-dazzle high beam?
According to Halsifer's cheat sheet, High Beam Assistant is needed in order to code Active High Beam Assitant/Anti-dazzle. Is the HBA option strictly necessary, or is getting the special ConnectedDrive branded camera all that is necessary?
I ask because I am ordering a 428i in Canada and in order to get HBA, one needs to order $6300 worth of packages. However, ordering Active Cruise Control as a standalone option appears to give you the same camera (the one that says ConnectedDrive) that you'd get when ordering HBA. My dealer doesn't think that it's possible to special order HBA on it's own, so I thought ordering the Active Cruise might allow me to code Anti-dazzle and Variable Light Distribution without having to order those packages. |
09-07-2014, 09:57 PM | #2 |
27
Rep 145
Your dealer should be checking rather than "thinking"..... I got to cherry pick certain options as part of my negotiation process and my dealer would be checking with BMW to see if the options (origibally part of other packages) where available as stand alone. Good luck!
2018 X3 30i / Alpine White
09-08-2014, 02:30 PM | #5 |
251
Rep 640
It's an option. You should be able to order it without those packages. In fact, I can even option it as an independent feature on a stripped 328i for $250. Your dealer should get their facts straight.
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP 2010 Audi S5 4.2L [Sold] 2014 BMW 335i xDrive M-Sport [Sold] 2010 Audi A6 3.0T [Sold] |
09-08-2014, 04:52 PM | #7 |
27
Rep 145
In Canada options have the same coding but the packages they are part of, that fiffers. Nonetheless, it is possible to get them as an individual item.
09-08-2014, 08:16 PM | #9 |
BimmerPost Supporting Vendor
569
Rep 987
Drives: 2022 X4 M Competition F98 LCI
From my understanding, to have Variable Light Distribution, you'll need the adaptive headlights. I'm sure the High Beam Assistant will work with just the standard bi-xenons that come with the F32.
09-08-2014, 09:36 PM | #10 |
Rep 10
Yes, I'll be taking the Active LED Headlamps option. I'm just trying to figure out how to get full functionality (as in Europe) with them.
09-08-2014, 09:46 PM | #11 |
Rep 10
I spoke to my CA about ordering HBA alone, along with a few other items that would normally come in packages. Apparently, a request has to be submitted to BMW Canada, which they can either approve or deny. Does this sound right?
09-08-2014, 11:31 PM | #12 | |
569
Rep 987
In terms of the HBA, it seems that it shares the same camera (it appears, not sure) with the Speed Limit Info ($350). Only reason I say that is because it seems people with HBA can enable the Speed Limit Info somewhat. |
09-10-2014, 05:40 PM | #14 |
27
Rep 145
My understanding is that "packages" are defined by countries (BMW Canada), the factory can do pretty much any type of combination... My 320i base/no line has heated steering and lumbar support that are definetely part of other packages. I even got Liquid Blue metallic colour, which is only available on the hybrid.... On the other hand, when I ordered heated seats, BMW Canada said I couldn't have rear heated seats ("Not possible") when it's an option in the US model. Go figure, the marketing "geniuses" always spoiling the party!
09-10-2014, 06:58 PM | #15 |
Rep 10
Right, I had figured that this was simply the BMW Canada rep displacing blame to BMW itself. But if BMW Canada is saying "no," then what more can I do? To give it one more try, I asked my CA to inquire about ordering HBA as my only special order option. I'm hoping they'll be more receptive to this since I'm not asking for any other items that are within packages.
09-10-2014, 11:12 PM | #16 |
569
Rep 987
Well as I've mentioned before, if they won't, try adding Speed Limit Info and then see if you can code HBA with the Speed Limit Info KAFAS Camera. It may or may not work but its around $250-350 for the option anyhow.
09-11-2014, 12:31 AM | #18 | |
569
Rep 987
In F-Series cars, I believe it should just be finding the right parameter that allows the HBA checkbox in the iDrive like how one could enable the DRL checkbox... not that anyone would want to do that. In theory, if you were to code in HBA, it is permanently ON when you turn on your High Beams. The power of E-Sys! |
09-11-2014, 09:21 AM | #19 |
Rep 10
Unfortunately, taking Speed Limit Info requires taking the Premium package on the 4 series (according the the configurator, anyways). This doesn't really make sense though, since the extended instrument cluster where the speed info appears is standard equipment.
09-11-2014, 10:51 AM | #20 | |
1404
Rep 5,262
Also coding automatic HBA is not available anymore on the F30 or F22.. i think only the F10 allows it...(FRM 3050 FLA_AUTO_AKTIV) |
09-11-2014, 01:38 PM | #21 | ||
251
Rep 640
2018 Audi RS7 4.0T
09-11-2014, 03:39 PM | #22 | |
Rep 10
