09-06-2014, 12:51 AM | #1 |
65
Rep 260
New Firmware: NBTG.. HUD Junction view
On previous versions of the NBT if you coded HUD Junction View you would get an unreadable image for the junction. The functionality was pretty much useless.
I decided this option now in the NBT after the update to NBTG firmware and Bingo clear and awesome feature enabled, great feature! |
09-06-2014, 08:22 AM | #2 |
158
Rep 1,573
can you take a picture? id like to see it working.
theres a similar option on CIC, but when I activate it...it crashes the i-drive
2015i Cadillac Escalade ESV
09-06-2014, 10:57 AM | #3 |
65
Rep 260
09-06-2014, 11:26 PM | #4 |
819
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
what's a junction view?
09-07-2014, 08:59 AM | #6 |
819
Rep 3,341
Holy bejesus that looks so much better than our current HUD!
Firmware is updated at dealership? |
09-07-2014, 09:06 AM | #7 |
158
Rep 1,573
NBT is the newer generation idrive....its a hardware update...so no, you cant have firmware upgrade
09-07-2014, 10:34 AM | #8 |
65
Rep 260
09-07-2014, 10:51 AM | #9 | |
16
Rep 50
09-07-2014, 11:48 AM | #10 | |
65
Rep 260
I just updated to the 2015 maps for my country. Since this is MAP dependent I am going to see if the images change I agree this is def one of the nicest features of the HUD. |
09-07-2014, 02:26 PM | #11 | |
658
Rep 1,479
Drives: 2020 M340Xi (G20)
This is really great; all I get is an orange schematic rendering in my HUD. I have two questions:
Thank you very much
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
09-08-2014, 05:48 PM | #13 |
General
10461
Rep 40,864
Drives: 2018 Alpina B6 650ix GC
Understand that anytime you flash new firmware on an ECU, you run the risk of bricking it.
But is you choose to flash it, you will need E-Sys with PSdZData Full version, and to put the car on a commercial grade charger, good for 50 amps minimum, as you cannot run the motor while flashing. Here are the basic steps to flash NBT and HUD: Go to Comfort Mode => TAL-Calculating - Read and Save FA - Activate FA - Read and Save SVT Actual as SVT_ist - Create an SVT Target Under KIS/SVT Target Calculation Strategy, select Complete Flash Select I-Step (shipm.) to match your original I-Level as read and shown in VCM I-Step (Shipment) I-Step (target.) will be unselectable as it is fixed based on current PSdZData I-Level Do a KIS/SVT Target Calculation and Save as SVT_soll - Do a TAL Calculation and Save as SVT_tal Go to Expert Mode => TAL-Processing Load TAL (SVT_tal) Load SVT Target (SVT_soll) Select "Read FA" button. Check radio button for "read VIN out of FA" On ECU Tab, uncheck let top box in column "All" (All checked boxes should toggle to unchecked) On ID Base Row for HU_NBT, KOMBI, and HUD make check boxes in blFlash, swDeploy, cdDeploy, and ibaDeploy columns. Press Check software availability Press Start and it will proceed with processing TAL to flash NBT, KOMBI, and HUD with new firmware.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 09-08-2014 at 07:05 PM.. Reason: Added KOMBI |
09-08-2014, 06:48 PM | #14 | |
658
Rep 1,479
I'm a little confused. While I understand your very clear explanation of flashing an ECU to update firmware, if your car had an ISTA/P upgrade, does that include what flashing ECU would accomplish. Specifically, I have an H series HU_NBT in my 2014 F30, but while at dealer recently, car had its ISTA/P upgraded to 2.53.2 -- 2.53.3; did that accomplish the same as if I were to flash HU_NBT? If so, then I guess, the question is what is MyFastM3 new Integration level? Am I missing something?
Al
09-08-2014, 07:07 PM | #15 |
General
10461
Rep 40,864
Yes, dealer programming the car with ISTA/P and Flashing with PSdZData accomplishes the same thing.
If you are on 53.3, and you have coded HU_NBT => JUNCTION_VIEW_HUD = aktiv, and yours does not look improved like his does, then his car may be on 53.4 or 53.5. Hopefully it is not a hardware issue where the F80 Kombi / HUD is different. Obviously ///M Kombi is different, but I mean specifically related to the Junction View.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
09-08-2014, 07:13 PM | #16 | ||
658
Rep 1,479
Al
09-09-2014, 04:01 AM | #17 |
849
Rep 1,860
I coded this last night and it works perfectly on my 2014 week 10 (March) 335d with NBT pro nav which hasNBTG firmware running as standard from the factory
09-09-2014, 04:58 AM | #19 | |
849
Rep 1,860
I strongly suspect you don't have the HUD aspect of the full colour lane info with your CIC Nav |
09-09-2014, 05:31 AM | #21 | |
849
Rep 1,860
I found the orange lane arrows quite easy to overlook. |
09-09-2014, 10:37 AM | #22 |
Rep 21
this is pretty epic. my Schumacher INC-800A is on its way now, on site tomorrow so i can flash NBT (and code in my mppk!) what a great week in the history of my f30 haha
