09-05-2014, 03:58 AM | #1 |
47
Rep 287
Drives: '15 GT-R, '02 996TT
My M235i: DYNO Update (407whp / 450wtq)
Hey everyone!
I've been wanting to dyno, but work has kept me busy and summer has been way too hot to strap the car on the rollers. However, today was nice in SoCal, so I took my car to eAs to see what my car would put down with its current setup. I am extremely pleased with what the car is putting down and 1st, 2nd and 3rd gear are pretty much worthless right now . Current mods: aFe Intake ER FMIC ER Chargepipe ER Downpipe M-Performance exhaust JB4 +FF + EWG Wires + E35 fuel mix + Map 6 (16 psi) The lovely dyno sheet: Last edited by JustinCredibleM; 10-15-2014 at 01:39 PM.. |
09-05-2014, 05:38 AM | #2 |
Rep 100
Great numbers and beautiful sound.I think you may have convinced me on the downpipes .
I am sure there is still some power you are leaving on the table. I know different Dyno,day.conditions but mine made almost exactly the same with same fuel with only MPE/jB4 after Terry adjusted the map.I can post my graphs to compare but don't want to steal any of your thunder!- mines too quiet anyway.lol I am sure your mods are worth and additional 20-20 whip. |
09-05-2014, 06:54 AM | #4 | |
1777
Rep 4,515
What map did you use for the dyno pulls ?
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
09-05-2014, 07:05 AM | #5 |
256
Rep 1,040
See you finally reached your 400+ HP goal! Nice job. After my trials with a couple different piggyback tunes I decided to not do the build-out. Will try a different branded Stage 1 plug-in next week, but this is about all I really want to do with the car.
Very impressed with your numbers and work you done thus far. Enjoy every minute behind the wheel of your labors... |
09-05-2014, 08:44 AM | #7 |
413
Rep 678
Very impressive numbers, graph looks good !!!
How is the drivability under normal driving compared to stock? How is idle and cold startups and initial drive before complete warm up? Did you happen to get the SAE numbers? Very nice !!!
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
09-05-2014, 09:31 AM | #8 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Awesome.. this is no doubt Map 7.
What octane/fuel mix are you using? I was happy with 351.. but this makes me want to catch up!
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
09-05-2014, 09:52 AM | #9 |
262
Rep 528
Good deal! It took me 2 hrs to get home yesterday so I shouldve stuck around and watched the run. 91 traffic was BRUTAL. Great meeting you, thanks for all the advice and tips! (you and Brian)
09-05-2014, 12:16 PM | #12 | |
Rep 100
Apologies not trying to hijack your thread. Runs were on Map 7- forget to have files sent but I have print out. Apologies for poor quality. |
09-05-2014, 12:46 PM | #14 | |
Rep 100
May be the additional mods he has ?(Intake,down pipes) could it be the smoothing?I will replace that photo with the dyno file when he sends and smooth at 5 and see. |
09-05-2014, 01:04 PM | #15 |
What goes here?
450
Rep 1,356
Yeah I dyno'd my car at the same place olaosunt did and I just think it is the smoothing they use.
2019 G30 M550i
09-05-2014, 01:58 PM | #16 |
2672
Rep 3,403
The graphs look very similar. It's just smoothing.
Are you guys running Map 7 and E30 daily? I run 4 gallons of E85 to a tank of 91 since I have an E85 station 3 miles from my office so might as well try Map 7...just gotta get some Map 2 logs over to the guys first for the all clear first. Curious, Justin...have the BMS guys reviewed your logs and informed to tweak any of the settings, or are all the settings standard mapping as delivered on the JB4? |
09-05-2014, 02:07 PM | #17 | |
119
Rep 623
Which are you trying now if you don't mind sharing?
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec |
09-05-2014, 02:12 PM | #18 | |
What goes here?
450
Rep 1,356
Curious about this too. I'd like to see logs for these runs.. would be great if this was 'out of the box' Map 7 (?) and default settings. olasunt did say for his Map 7 setup (identical to Justin minus DP and intake but *SAME* power!) Terry suggested some 'tweaks'.
2019 G30 M550i
09-05-2014, 03:24 PM | #19 |
47
Rep 287
I forgot to list the map and boost settings, so I've updated the original thread. I am running Map 6 @ 16 psi. I am not using Map 7, because it runs you up to 18.5 psi and I didn't want to test it or push the car that hard. So I'm pretty happy that I made these numbers with 2 psi over Map 2 and 2.5 psi less than Map 7.
@olaosunt - I noticed you're using Map 7 which runs your car at 18.5 psi, however, I am running 2.5 psi less on Map 6 with 16 psi . I rather not push the car too hard to make the numbers and have it do it naturally on lower boost. @make_em_say_eun - I was on Map 6 (16 psi). @Delnari - Thanks buddy! Please post up how you do with the other branded stage 1! @snodgrass23 - I don't and I'll try to get one next time I am around the shop. @alz0rz - Its an E35 mix with 91/E35. I am not using Map 7, but I'm using Map 6 @ 16psi which is 2.5psi less than Map 7. @dt20011 - Nice meeting you too dude! I hope you enjoy the car in good health and try E85 sometime . @FC4 - They've reviewed it and it seems fine. I am not knocking and my ign_adv is pretty low. I run an E35 mix of 91/E85 and its been good to me so far. Curious what my numbers would be if I went up to Map 7 . |
09-05-2014, 03:28 PM | #20 |
47
Rep 287
09-05-2014, 03:30 PM | #21 |
***** noob
1368
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Can someone translate this to real world numbers? In Hp & Tq
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
