F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Brake sensor problem !
Studio RSR
      09-01-2014, 09:37 PM   #1
Dr.HiTcH
Dr.HiTcH's Avatar
No_Country
17
Drives: BMW f30 335i sport
Unhappy Brake sensor problem !
Hello everybody...
my problem is since i brought my car which is 15 month ago the front brake sensor was showing gradual decrease in the life time of the front pads.. but since 3 months it stop decreasing (its showing 2200 km =1367 miles to change front pads),,
so since 3 months the car says that the brakes are the same but the feeling is changing(the initial feeling when applying the brakes is fading away)!
anybody has this issue,,
really strange , i feel like if the car front pads need to be changed but the sensor is not working properly?!
      09-02-2014, 12:17 AM   #2
0715AW335XI
13
Drives: 2014 335i
Didn't even know there are sensors... How do I check them?
      09-02-2014, 12:20 AM   #3
10nelyboi
15
Drives: 2012 - 335I
I had the same issue, when I brought it in the tech looked at the brakes and said it still good. He updated the computer system
      09-02-2014, 08:37 AM   #4
Dr.HiTcH
Dr.HiTcH's Avatar
No_Country
17
after updating the system,,everything become normal again or the problem still their?
      09-13-2014, 04:19 AM   #5
10nelyboi
15
Drives: 2012 - 335I
yup everything was good after that
      09-13-2014, 11:20 AM   #6
40oz.
23
Drives: F30 335I, E46 325CI, E87 118d
I had the same issue . My front brakes stayed at 1400 miles for about 4 months. Then on the 2nd anniversary of picking up my car, I got the replace brake warning light. Since we only get a 2 year warrenty in Europe , I ordered the brakes to change myself. Took the brakes apart and the wear sensor wasn't touched yet. There was still a good bit of pad to go. So it looks like the brake sensor is supposed to go off before the mileage count stops if you're braking often and hard enough. And if you haven't changed them in a two year period the car tells you too. I could be wrong but that's what it seems like . I installed the new brakes with the old sensor and everything is fine.
M Sport , 6MT, Alpine White, Leather Dakota Black, Aluminum hex trim w/gloss black highlight, Premium Package, Tech Package, Cold Weather Package, 18in Wheels With Mixed Performance Tires
http://www.f30post.com/forums/showthread.php?t=722977
      09-13-2014, 01:52 PM   #7
paulbrenneman
paulbrenneman's Avatar
Drives: Mineral Grey 335i M-Sport ZF
Unless you have a warning light I'd just forget about the sensor. We can spend all day speculating about the accuracy of the sensor and debate where the mileage approximation is coming from but is be better to just visually inspect the pads. If the braking material is thinner than the thickness of the metal backing on the pad it is recommended that you get new pads. With german cars you really should do rotors at the same time as well. Make sure to inspect the inside and outside pad, there are two pads on each wheel
      09-13-2014, 01:54 PM   #8
CHCCubs
CHCCubs's Avatar
Latvia
97
Drives: 2013 BMW 328i xDrive Sport
I had the same issue with my car as it was calling for front brake replacement in 2,000km when my car was only at about 17,000km. When I took it in for the first oil change they updated the software and CBS and the interval went back to a far more reasonable number. From what I gathered from the service advisor this glitch was a known problem as he mentioned right away that the software update would correct it.
2013 BMW 328i xDrive Sport Line
Mineral Grey on Everest Grey
f30post
