Auxiliary fan issues
08-27-2014, 04:51 PM | #1 |
806
Rep 1,191
Can you guys do me a favor and measure the coolant temperature at which the auxiliary fan starts kicking in?
Mine rose to 96C today and the fan still didn't run so I switched on the AC which started the fan by default. I got concerned when I noticed that every now and then the fan kept running after I shut off the car. A quick research on the knowledge hive indicated that this is normal if you turn off your car while it was in the middle of performing a DPF refresh. However, mine kept running for more than 30 min until I thought there might be something wrong. I started the car and turned it off again which took care of the problem. Strangely enough, the fan responds fine to diagnostics request to the DDE, yet it threw me a code the other day indicating a problem with the fan. |
08-31-2014, 08:36 AM | #2 |
806
Rep 1,191
Bump. Anyone?
Please do the following test: Secure your car against rolling away, let the engine idle, AC off, put in gear to increase the load. Open the hood and watch the fan and "engine coolant temp" on the Torque App (or whatever). Please let me know at which temp (>87C) the fan starts running. Your help is greatly appreciated. |
08-31-2014, 06:55 PM | #3 |
870
Rep 2,615
I can run this for you when I come back from the long weekend. But I have never heard the fan come on unless it was for the ac or during a regen. I can look up the temp data as well if I ever hit the 96 before.
09-01-2014, 09:30 AM | #4 |
806
Rep 1,191
Thanks Yozh. Looking forward to your results. You might need to watch the fan as the DDE might only give it 10-20% PWM for temps just above 87C. At that speed the fan will probably inaudible.
09-04-2014, 09:02 PM | #6 |
870
Rep 2,615
Ok, at idle the fan does not turn on at 96c. When increasing the load the fan will come on (10-20pwm) at about 98c and will run until the temp drops to 95c. Hope this helps.
09-05-2014, 03:59 PM | #7 |
806
Rep 1,191
Thanks Yozh!
I feel much better now. It seems 98C is not a problem for the engine as we see those temps during regens, too. Yet, I'm still a bit baffled why the DDE doesn't start cooling the engine earlier. I confirmed today with 30C outside temps, the fan came on just before hitting 98C. Good to now that this is normal though. Thanks again! |
