08-25-2014, 11:18 AM | #1 |
14
Rep 40
F30 Alternator Engagement and Disengagement
Does anyone know where I can find diagrams (I have done searches but didn't find what I wanted) for how the Alternator Engages and Disengages?
Is it mechanical? Or is it electrical? (Electrical being something like not putting current to the coils, so the alternator spins with no field inside it, so does not generate electricity, and putting charge to the coils when you want more drag but also generation of electricity)? Just curious. Thanks. |
08-25-2014, 11:56 AM | #2 |
481
Rep 1,572
I don't believe the Alternator engages/disengages. Most cars require an constant output from the alternator to function due to the electricaly load in a modern car- the battery would drain pretty rapidly. It is engaged whenever the engine in running. It is not like the A/C compressor which does cycle "on" and "off"
08-25-2014, 10:08 PM | #3 |
16
Rep 247
There's a clutch in the pulley for the alternator that disengages while accelerating to reduce engine load. So the accessory belt spins the pulley but the alternator isn't spinning because the clutch isn't transferring the spinning motion to the alternator. Since the alternator isn't spinning, no power is generated.
I don't know how the clutch works though, I'd imagine a magnetic field would work but I really have no clue. |
08-26-2014, 12:51 PM | #5 | |
10
Rep 115
15' 335i XDrive - M Sport, MPPK, Dynamic Handling Package, Tech Package, Driver Assist, Harmon Kardon, Sport Automatic, Heat Front Seats, Enhanced Bluetooth. |
08-26-2014, 01:20 PM | #6 | |
50
Rep 1,730
UNDRSTR
08-26-2014, 02:24 PM | #7 |
14
Rep 40
You would think they could just change the field which is electrically driven, to avoid mechanical parts, to change how much resistance (and charging) you get from the alternator. A clutch wears out eventually.
Oh well, just something i was curious about. I assumed (but am not sure) that this is how the Prius changes the amount of regenerative braking that is being applied on the car. |
08-26-2014, 02:31 PM | #9 | |
50
Rep 1,730
The Prius has a motor in the drivetrain (Toyota have pretty advanced parallel hybrid drivetrains), therefore they just use the drive motor in reverse as a generator. Not sure if they can control the magnitude of energy flow into the battery, which would allow them to vary the regen brake torque. I believe they usually just have the regen happen and apply mechanical brakes additively once the driver requests more than the regen capability.
UNDRSTR
