08-18-2014, 08:50 PM | #5 |
29
Rep 633
It seems to me that Sport+ on my 435 (with PPK) has a more linear response on the throttle map.. not sure about the rest of the handling, but I can tell which mode it is in - they are a bit different.
08-19-2014, 06:45 PM | #6 |
Rep 18
On my '14 328i the steering gets tighter again as compared to sport. The throttle mapping seems different, gear shifts hold longer and traction is off as well...
08-19-2014, 06:52 PM | #7 |
29
Rep 633
And funnily enough, the car seems more predictable overall in Sport+, even with the DSC off.
08-19-2014, 06:54 PM | #8 |
343
Rep 2,118
Some say this is true (the steering). I disagree and BMW only claims that Sport + defeats traction control. I cannot tell a difference in the steering.
08-19-2014, 07:45 PM | #9 |
12
Rep 343
I could be wrong but I was under the impression that Sport+ decreases the the traction nanny a bit and returns the throttle mapping to comfort mode.
2014 335i M-Sport Mineral Grey / Sport Auto / Black Dakota / Aluminum Hex / Prem,Tech,DA packages / DHP / M-Sport Brakes / MPPK / MPE / Black Kidney Grilles, SS Pedals, M-Performance CF spoiler / Cameras, heated seats, etc etc
2013 X3 35i...wife's car |
08-19-2014, 07:54 PM | #10 |
29
Rep 633
Not sure, but I do drive mine in Sport + verses Sport for whatever virtual reality it sets up in my feeble head, it feels different .. placebo or not..
08-21-2014, 10:10 PM | #12 |
29
Rep 633
You have a 435.. just try it in all modes all week and make your own call to clear up your confusion. No one else matters.
08-21-2014, 10:25 PM | #13 | |
772
Rep 1,502
Basically sport+ gives you sport chassis settings (if you have DHP), sport steering, DSC off, sport shifting (for autos) and comfort throttle. A BMW engineer said in an interview that the linear comfort throttle setting is better for track work due to predictability and easier fine-grained adjustments. |
08-22-2014, 02:41 AM | #14 | |
55
Rep 681
Moreover, DHP settings are exactly the same in Sport and Sport+, as well as throttle response, steering and shifting speed Sport and Sport+ are different only for the activation of DTC in the latter program. If you have 8AT, there is another important difference: in M it holds the gear at rev-limiter and it doesn't do any automatic kickdown (as well as in DSC Off and Traction program, always in M mode)
BMW M3 G80 Isle of Man
08-22-2014, 03:39 AM | #15 | ||
118
Rep 1,002
Unless you initiate Launch Control, in which case even if you're in Manual paddle shift "M" mode and launch, I think it still shifts for you at redline? |
08-22-2014, 08:06 AM | #17 | |
55
Rep 681
If you want to activate LC procedure, you cannot be in M mode, but only in S with Sport+ or Traction program: in that case, of course, it will shift for you at redline PS throttle response is set back to "confort" only in DSC Off program, in wich all the other parameters (shift speed, steering and dumpers) are set in "sports"
08-22-2014, 10:38 AM | #18 | |
772
Rep 1,502
SPORT+ Consistently sporty control of the shock absorbers for greater driving agility when driving with limited driving stabilization. Activating SPORT+ Press the button repeatedly until SPORT+ appears in the instrument cluster and the DSC OFF indicator lamp lights up. |
08-22-2014, 10:53 AM | #19 |
772
Rep 1,502
Found that chart I was thinking of. I admit to being thoroughly confused about the whole DSC OFF thing, as the chart seems to imply that DSC OFF is separate from Sport+, but the manual says the DSC OFF light comes on when you engage Sport+.
The chart was posted by DVC in this thread: http://f30.bimmerpost.com/forums/sho....php?t=1011676 |
08-22-2014, 11:10 AM | #21 |
12
Rep 343
Looks like I was confusing some features of Sport+ and DSC off as well.
Looks like Sport+ IS the way to go (even if it does have DTC enabled) and I'll start using it now. Before I only ever used Sport since I didn't fully understand Sport+, this chart is great. I also thought that Sport+ disabled/reduced DSC and that is why DTC was active but I guess not. DSC-off mode sure looks strange--some features form sport/sport+ and others from comfort.
08-22-2014, 11:51 AM | #22 | |
127
Rep 764
