Need refrigerant pressure sensor pins on JBE
08-16-2014, 08:42 PM | #1 |
Rep 3
Hi all, as the title says I'm looking for the refrigerant sensor pins on JBE (it should be the same for E90 through E93, from 2008+).
The Bentley manual on the page ELE-250 (Heating and AC) shows the coolant pressure sensor, and there is no any mention of refrigerant pressure sensor - I'm not sure if that was just a typo in the book? Oh, and the reason I'm looking for this is that engine wiring was cut all the way to the firewall, and in putting it back it seems some wires got crossed/missed. So, now IHKA does not have the input from the refrigerant pressure sensor. Thank you for the help! |
08-17-2014, 09:37 PM | #4 | |
Rep 3
I actually have no problem finding the location of the refrigerant pressure sensor (as you said, it's on AC line right below the coolant expansion tank, hidden by the heat shield). What I'm looking for is the information on where those sensor wires end up in the vehicle (the other side from the pressure sensor), what connector and what pin numbers. Thank you much! |
