08-15-2014, 07:02 PM | #1 |
64
Rep 251
Drives: F30 - E92, E90, E46 (Retired)
Doors pins rattles.
Hi. 3 of my 4 doors pins rattles, it's the plastic pin that rattles against the plastic hole it sits in. There is just enough movement that certain bumps will cause the pin to knock into the surrounding material. Only one of the rear doors doesn't have the same problem as that pin sits under some kind of tension.
Does anyone has this problem and solutions. Thanks in advance. |
08-15-2014, 07:49 PM | #2 |
Rep 30
I had this problem with my E60 and fixed it by taking the soft half of thin Velcro strips, cutting them to fit the inside circumference of the hole and sticking them in place by stuffing the piece down the hole. Worked likea charm. My F30 doesn't do it. Yet...
335iX M-Sport | Estoril Blue II | Black Dakota | Aluminum Hex | Premium | Cold Weather | Technology | 403M Wheels | 8SPAT w/paddles | Blacked Out Kidney Grills | Rear Spoiler
08-16-2014, 10:47 AM | #4 |
13
Rep 411
Electrical tape?
johnsedlak.com - web developer, designer
08-17-2014, 12:00 AM | #5 |
64
Rep 251
It is a clever solution. I though to use velcro but it has no enough space.
Meanwhile my dealer said BMW order to change all 4 pins free of charge. But I am resilient because I am thinking it will be not durable solution, because the pin will knock into the surrounding material again. |
08-17-2014, 07:59 AM | #8 |
301
Rep 718
+1 for Velcro. Are you sure it's the door pin though? Last weekend I pulled my door panel and found all the plastic clips were very loose and rattling. I put soft velcro behind each one and the problem was solved. Sorry, no pics. Also, the foo light (on the underside of the door) was loose. Popped it out, wrapped it in velcro and popped it right back in. Car is rattle free...for now. I also have an earlier post where I pulled off the plastic door handle and tightened the screws behind it.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!) |
08-17-2014, 01:36 PM | #9 |
64
Rep 251
08-17-2014, 01:38 PM | #10 |
64
Rep 251
No really, just minimize the rattle a bit.
08-17-2014, 01:44 PM | #11 | |
64
Rep 251
In my case is the door pin, a technician from my dealer verify the situation and putting the hand over the top of the pin the rattle stops. But thanks anyway. |
08-18-2014, 09:22 AM | #12 |
19
Rep 312
Interesting. I have a rattle on my left rear door around that area that I can't figure out where's it's coming from (other than close to my ear). Will definitely check this out as a possible culprit.
08-18-2014, 10:18 PM | #14 |
304
Rep 1,739
When you remove the covers on the door handles to get to the screws, do you pry from the bottom first? I notice there's a little notch at the very bottom, out of sight. I'm wondering if you push the pry bar in that slot.
08-19-2014, 10:17 AM | #15 |
Rep 93
Things don't usually just start rattling for no reason, I'd pull the door panel and get a better look. Haven't done it on an f30 but it was very easy on e90, I imagine it isn't too different
08-19-2014, 12:30 PM | #16 | |
301
Rep 718
Also, the wires going to the window switches were long and dangling between the door and panel and may have contributed to some of the rattling. I taped them to the door before I put the panel back on.
08-19-2014, 01:10 PM | #18 |
64
Rep 251
08-19-2014, 01:31 PM | #19 |
118
Rep 1,668
No, that's the trunk not the pins.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
08-20-2014, 12:42 AM | #21 |
131
Rep 350
08-20-2014, 02:41 PM | #22 |
33
Rep 326
