The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d - Dyno Runs, Numbers, Data
      08-15-2014, 02:29 PM   #1
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
All of the dyno data is strewn around different threads and it is hard to find. May be we should have it all in one place.
Here is Mine:
-2011 335d, Ecotune, DPF Delete, DEF is still spraying, EGR blocked
-Dynapack Dyno
-Weather: 20-21C (68-70F), 77-78% Humidity, Pressure 1015-1018 hPa
-Two Pulls, fan blowing into an intercooler and another into a radiator
-Can only do two pulls as it was a smoke show, there is a lot of unburned diesel even after full fuelling
Here is the Dyno Data:
Name:  Taras2011335d power.JPG
And associated parameters (Temp is in deg C), you can see where there two pulls are done:
      08-15-2014, 02:40 PM   #2
joe_planet
41
Drives: 2011 X5d
nice man, solid numbers!
      08-15-2014, 03:01 PM   #3
DieselRacer
BMW Advanced Diesel, 2011 BMW 335d M sport...
DieselRacer's Avatar
87
Drives: 2011 335d M sport
I hope I get that kind of power with the Mega Speed tune...
BMW Advanced Diesel, 2011 335d M sport...
      08-15-2014, 03:22 PM   #4
TorqueAddict
TorqueAddict's Avatar
171
Drives: 340i - 335D
You *may* be able to touch 280-290 with just the tune, that is my estimate. If you want to go higher, you will have to remove DPF.
      08-15-2014, 03:38 PM   #5
335ddd
Drives: 2011 335D SE
this is at the wheels right?
      08-15-2014, 04:29 PM   #6
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
Eagerly awaiting your dyno topic man.
      08-15-2014, 05:03 PM   #7
TDIwyse
614
Drives: 2011 335d
I love that you are posting raw data. Thanks.
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods
      08-15-2014, 05:17 PM   #8
DieselRacer
87
[QUOTE=TorqueAddict;16473260]You *may* be able to touch 280-290 with just the tune, that is my estimate. If you want to go higher, you will have to remove DPF.[/QUO
So if I remove my DPF I will gain 40hp, no way in hell...
      08-15-2014, 05:49 PM   #9
anielsen71
Denmark
559
Drives: F36 435xd
@dieselracer
I gained aprox 40hp and 70nm by removing the dpf and a retune on my 330d.....
Brgds
Allan
‘15 F36 435xd Gran Coupé
Ex: E46 330d, E91 330dA
      08-15-2014, 06:04 PM   #10
DieselRacer
87
I removed the dpf on vw and audi diesels and gained 10hp,,,lol 40hp is almost more than the tune provides, so without my dpf I should gain 70hp, that's not even possible...to the wheels...???
      08-15-2014, 06:27 PM   #11
Yozh
Yozh's Avatar
No_Country
870
Yes, at the wheels. Dynapack is an axle dyno, not a roller one. Techs at the shop said that for that dunno, those were very good numbers. They had a heavily modified Porsche before me and it was pulling 600 lbs of torque. But it's all subjective I suppose.
      08-15-2014, 07:46 PM   #12
2deerwhistlers
109
Drives: 335d
We both ran on the same type/brand dyno and our results were almost identical
      08-15-2014, 11:17 PM   #13
BayE30
1341
Drives: 2011.75 E90 M3 ZCP
those numbers to the wheels are awesome IMO. I am going for a very similar setup eventually.
      08-15-2014, 11:58 PM   #14
DieselRacer
87
What is baseline hp, if its 245hp like my car was that's a 80hp to the wheels with just a tune and DPF delete??? Which is like gaining over 100HP at the fly, most impressive tune and numbers I have ever seen...I should have got this tune cause mine is going to be no where near these numbers even with a DPF delete on my car...
      08-16-2014, 02:08 AM   #15
Yozh
Yozh's Avatar
No_Country
870
You never know, but you will be comparing apples and oranges anyway. You are not doing a DPF delete if I recall correctly. Even same mods but dyno to dyno will have quite a bit of variability as others have pointed out.
      08-16-2014, 02:14 AM   #16
DieselRacer
87
No DPF at this time for me, I just want my car back, lol...
      08-17-2014, 10:03 PM   #17
austinla335d
53
Drives: 2011 335d
I've seen a dpf delete hurt the car via the ECU (fuel reduction), so it's not just freeing up the dpf restriction, it's the lower EGT's that avoid consequences. It may add 20hp, and reduce 20hp worth of restriction. That is possible.
      08-18-2014, 07:05 AM   #18
2deerwhistlers
109
Drives: 335d
Your car is 265 hp from the factory.. So there's 20 hp out of dark matter
      08-18-2014, 10:25 AM   #19
DieselRacer
87
My car dynod at 245, most of them do...
      08-18-2014, 10:44 AM   #20
2deerwhistlers
109
Drives: 335d
Sorry i misunderstood.. With a dpf delete tune and downpipe you should put close to 330 hp to the wheels
      08-18-2014, 03:39 PM   #21
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
Let's see my OEM DYNO was 230 whp no torque was done. Last dyno w RENNtech flash Wagner IC 327 whp and 452 wtq imagen what am I going to get w the dpf egr scr deletes and downpipe w 3" exhaust w mufflers. Anyone wants to take a guess? Maybe 350 whp w 490 wtq who knos and the great thing here is THAT NO CODES have come up woohoo! !
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD
Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now)
      08-18-2014, 03:48 PM   #22
DieselRacer
87
Your not going to gain 120whp with a tune and dpf delete with exhaust, Im sorry but the numbers are getting way way over inflated...Dyno's lie and so do the people selling the tunes...
