Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Tire Failure While in Desert
      08-14-2014, 05:28 PM   #1
335dFan
Jumping Jack Flash
335dFan's Avatar
321
Drives: 2021 X3 M40i
When running a good amount of negative camber it pays to check the inner rib once in a while. This is what 3 of mine looked like when my right rear gave out 53 miles from nowhere.
This is the left front tire. The right front was not through to the fabric.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d
Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al.
      08-14-2014, 05:36 PM   #2
335dFan
Jumping Jack Flash
335dFan's Avatar
321
Pic 2
      08-14-2014, 05:41 PM   #3
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
How many miles ? Those look like michilen PSS
      08-14-2014, 05:44 PM   #4
335dFan
Jumping Jack Flash
335dFan's Avatar
321
Pic 2. This was the right rear. The one that gave up the ghost. Down to the steel cords.
      08-14-2014, 05:45 PM   #5
335dFan
Jumping Jack Flash
335dFan's Avatar
321
Pic 3. Yes Michelin PSS. 25k miles.
This was the left rear tire. Down to the fabric.
      08-14-2014, 05:48 PM   #6
DieselRacer
BMW Advanced Diesel, 2011 BMW 335d M sport...
DieselRacer's Avatar
87
Drives: 2011 335d M sport
I run 2 degrees camber which is the least that I can, my car is low so I should run more but this is why not...
BMW Advanced Diesel, 2011 335d M sport...
      08-14-2014, 06:13 PM   #7
PR3CI5N
need4speed
PR3CI5N's Avatar
510
Drives: 2010 E90 M 335i
Seems like bad tire day. This was my morning
N54
      08-14-2014, 06:19 PM   #8
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
Hope you had a spare. Why do you run so much neg camber? Offset/fit of the wheels?
      08-14-2014, 06:22 PM   #9
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
I run -2.0 in the rear and -2.5 up front. This is my third summer on my PSS and just a bit less mileage than yours. They look nothing like that.
      08-14-2014, 06:29 PM   #10
FormerRotor
FormerRotor's Avatar
96
Drives: 2011 335d, M-Sport
Sorry to hear that dFan. That's a bummer. What are your camber specs? I don't seem to remember them being too crazy aggressive (aggressive, just not crazy aggressive)
My Picture Threads (Oldest to Newest): 1 2 3
Join BMW CCA! (Use my link and I get credit )
      08-14-2014, 09:21 PM   #11
BB_cuda
BB_cuda's Avatar
765
dFan has the M3 suspension upgrades. Is there more to story than -2.0 camber maybe?
      08-14-2014, 09:35 PM   #12
DieselRacer
87
Has to be chamber, the Z3 from the factory use to leave with like 6 degree champer and they would get 6k miles out of them, unless its rubbing somewhere under the fender due to ride height, but im and inch or two off the ground and have no wear like that, knock on wood...
      08-14-2014, 09:37 PM   #13
joe_planet
41
Drives: 2011 X5d
I think something else is going on here, when did you have your last alignment?
      08-14-2014, 09:38 PM   #14
GreekboyD
411
I have those too.
I'm running -2.5 up front and my tires look nothing like that.
Could be his toe settings that caused the excessive wear. What is your "toe out" specs for the rear?
EDIT: I don't think the added extra weight of that trip you took recently helped the situation either.
      08-14-2014, 10:49 PM   #15
335dFan
Jumping Jack Flash
335dFan's Avatar
321
I would have preferred this puncture to my failure. Although far from civilization I had plenty of space to operate.
      08-14-2014, 10:52 PM   #16
335dFan
Jumping Jack Flash
335dFan's Avatar
321
I had a donut spare with tools, some slime, a plug kit, and a good portable compressor. Good thing because I had no signal (0 bars) on my hand phone.
      08-14-2014, 11:00 PM   #17
335dFan
Jumping Jack Flash
335dFan's Avatar
321
Don't have alignment sheet with me. 25k miles ago was the last alignment for the rear and I don't remember the setting. Fronts were done about 7-8k ago after VAC repaired my front struts. Their printer was out of paper and I forgot to ask. 25k ago they were about -1.7 degrees as I recall.
Note all four were wearing out the same exact way at slightly different rates.
Good thing it didn't happen at 100 mph.
      08-14-2014, 11:02 PM   #18
335dFan
Jumping Jack Flash
335dFan's Avatar
321
The heavily weighted trip probably accelerated the wear pattern I am guessing. A lot of hard core mountain driving on coarse surfaces contributed too.
      08-14-2014, 11:10 PM   #19
335dFan
Jumping Jack Flash
335dFan's Avatar
321
Btw I replaced them with Nitto Motivos. Same size -- 235/40-18 square. Softer but they inspire less confidence in the bends. But I have had them less than 12 hours so time will tell.
      08-14-2014, 11:39 PM   #20
Quasimodem
Quasimodem's Avatar
147
Drives: 335d
2009 335d US  [0.00]
You know they make plug kits. Using a bolt is a bit too "redneck".
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
      08-14-2014, 11:42 PM   #21
austinla335d
53
Drives: 2011 335d
The Motivo's are great for comfort and mileage. So are Conti DWS or DW. The Motivo's price point is the best part
I'm on Michelin PSS and have around 15k miles- they are incredible. 7/32 and 6/32, even wear. My camber is -2.0 out back and -1.4 up front (the least I could get). Literally even tread wear all around, but I have had the tires balanced/side-swapped once and will do it again in the next few months.
I agree with the others- lots of weight, high neg. camber and sandpaper roads for thousands of miles.
      08-15-2014, 12:16 AM   #22
AzureHaze
AzureHaze's Avatar
69
Drives: 2011 335d Sport
Wow, same thing happened to me one morning a few months ago with the exact same type of screw...bolt...whatever the hell that is. Where do these come from anyway? Luckily I was able to patch it up at a nearby shop but they did a shitty job since there was a slow leak so thanks to my tire warranty with America's Tire, I got a replacement. Almost two weeks for them to get one though because the PSS is in such high demand!
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
