08-09-2014, 08:35 PM | #1 |
327
Rep 1,490
How many miles does your F30/F32/F33/F36 have? Any problems?
This thread is targeted towards those who have had the car for an extended period of time. Has it had any problems?
My car: 2014 F30, Sport, N20 328I, 8AT, AWD. Currently: 1800 Miles. No problems but I'd expect that on any new car less than 30K miles . My E90 was at 87K miles when I gave it to my sister. My TL had 145K miles when I got rid of it, and my E36 I took up to 165K miles
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
08-09-2014, 08:43 PM | #2 |
28
Rep 95
Been 6 months and about 8K miles. No issues to report yet (knock on wood).
2022 M3 Competition xDrive, SPY/YMB
2001 Porsche Boxster S 6MT, Lapis Blue 2017 Porsche Macan GTS, Carrera White 2015 Maserati GranTurismo Sport, Bianco Eldorado |
08-09-2014, 09:38 PM | #4 |
222
Rep 771
have had it for 8 months and 6k miles on the dot and no problems yet. The only think i have a problem with is the noise that is made on the silver trim on the steering wheel, it sounds really cheap.
08-10-2014, 10:24 AM | #6 |
24
Rep 293
60,000 miles on my 13 M-Sport 335 xi MT. (I drive alot)
Had small issues with Brake Squeal from 0 - 20,000 miles (Rotors and Pads Replaced on front and rear) Started experiencing limp mode a total of 10 times across 40,000 miles through 60,000 miles (In the shop for this for the 2nd time now, last time they did a system reprogramming and the issue came back) Grinding going into 2nd gear that was sporadic to now happening almost every time you shift into 2nd. Dealer thinks this could be a bad syncro which would result in a new trans. (In the shop for this waiting for an answer) I got platinum extended warranty and extended maintenance through 100,000 miles. Last edited by jbr5049; 08-10-2014 at 10:44 AM.. |
08-10-2014, 10:54 AM | #7 |
26
Rep 195
Drives: 435i XDrive M Sport MPPK+MPE
1100 miles with 0 problem and 100% of fun !
08-10-2014, 12:08 PM | #8 |
251
Rep 640
2014 335i xDrive
8700 miles. Nothing big.
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP 2010 Audi S5 4.2L [Sold] 2014 BMW 335i xDrive M-Sport [Sold] 2010 Audi A6 3.0T [Sold] |
08-10-2014, 02:50 PM | #9 |
38
Rep 387
2013 328i Sport Line.
30,000 miles. The only issues we've ever had was, on two occasions, when putting the transmission into R immediately after a cold start the engine stalled. I surmise idle control wasn't quick enough to react to the extra load placed on the engine by the torque converter. |
08-10-2014, 03:54 PM | #10 |
215
Rep 558
2013 335i sportsline, RWD, 8AT, 21,000 miles
- At the 750 miles mark, got limp mode. BMW replaced turbo and reprogrammed. Didn't have problem ever since. - Brakes squeal when they're cold. Bit embarrassing, but I'm going to put Stoptech BBK soon. - running on bms stage 1, afe intake, pss10 suspension, 20' rims. I do my own maintenance from then on since they fixed the limp mode. |
08-10-2014, 10:03 PM | #11 |
Rep 222
2013 328 Msport. 14500 miles.
All 4 rotors replaced under warranty for warps and passenger power seat switch doesn't work on hot days. Lots of b pillar rattling too, not fixed. Car is fine otherwise |
08-10-2014, 10:59 PM | #13 |
Rep 30
My car: 2013 335xi, 22K miles and "babied" re maintenance, care.
All was perfect until at about 1K miles ago the alternator belt tensioner seized up wrecking the belt and causing battery to discharge and water pump to stop/ engine to almost overheat. I did limp mode for 2-3 blocks to safe parking area where dealer's truck carried car back to the shop 2 miles away. Car repaired overnite and I picked her up next morning; no problems since. |
08-11-2014, 06:47 AM | #14 |
649
Rep 4,323
2012 base 335i with PPK
35k and free of any major mechanical issues-minor quibbles the dealer took care of. I have the 100k/6 year platinum.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
08-11-2014, 06:58 AM | #15 |
16
Rep 255
2013 335i M Sport, 8AT w/tune, dp, cp, intake, muffler delete
Tail light internal bracket ruptured within the first couple of months owning the car. BMW replaced it. Three tires (19" Goodyear summer run-flats) have developed bubbles in the sidewall. BMW replaced all of them under the wheel/tire protection warranty. Not really an issue but the carbon fiber gear selector lever trim has a piece on a corner that sticks out ever so slightly but just enough to clip fabric / my skin lol. Never complained about it but it bugs me sometimes (mostly when I'm cleaning up and it catches the microfiber towel). Otherwise, no issues that I can recall! Last edited by GhazaliGTE; 08-11-2014 at 12:32 PM.. |
08-11-2014, 07:34 AM | #16 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
2/2013 build 335i M-Sport, 8AT, MPE, MPPK, DHP: 17 months, 10.7K miles, 2 minor fixes:
1. Aux cooling fan replaced at ~5K miles per SIB (defective fan batch from mfr) 2. Brackets in brake calipers replaced at 10K miles per SIB (design flaw causing low-speed squeaking at 3-4 mph) Consistent high-20s combined mileage with mid-30s on the highway. No oil consumption.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
08-11-2014, 11:40 AM | #17 |
46
Rep 119
2012 328i luxury, 19000 miles, not a single issue, great car, 32mpg, 70/30 hwy/city
"Mankind requires 4 elements to survive on this planet...
Air, Water, Fire and Sportscar" -Bill Frank |
08-11-2014, 02:30 PM | #18 |
Rep 84
2013 335xi w/ MT... 35K on it. had to replace one rim and one tire (different wheels) due to the brutal winter and ensuing potholes. other than that, nothing (though i do have a small rhythmic thumping that could be another rim issue...thankfully i got the wheel insurance).
08-11-2014, 03:07 PM | #20 |
Rep 33
850 miles, only problem few dead bugs on the grill. Took it in for a wash, all good now!!!
2014 435i Convertible
M Power Kit M Sport Brakes Alpine White Burl Walnut wood, Dakota Black/Blue Highlights |
08-11-2014, 05:04 PM | #21 |
97
Rep 2,101
2013 328i xDrive - currently at 23,000km - took delivery in December 2012 and have not had any issues at all.
2013 BMW 328i xDrive Sport Line Mineral Grey on Everest Grey |
