08-09-2014, 04:33 PM | #1 |
112
Rep 969
Yet Another Stock Dyno Run
I got to run my car on the dyno today. 406whp and 402wtq. It was on a superflow dyno which usually reads pretty low. I'm impressed!
That torque curve is insane. When 2500 hits and that torque ramps up like that you could def hear it on the dyno. |
08-09-2014, 08:40 PM | #5 | |
112
Rep 969
08-09-2014, 11:22 PM | #10 | |
112
Rep 969
But seeing that reading low.. Makes me feel petty good about the m3 haha. |
08-09-2014, 11:29 PM | #11 |
Bored all the time
382
Rep 2,173
Probably a stupid question, but I'll ask it anyway... Why does torque drop so much after 3800?
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3... It all started with an RX-7 (FD). |
08-10-2014, 03:35 AM | #12 |
1712
Rep 5,109
Nice numbers, but somethings definitely off with the power plateau up top... It only keeps max power for roughly 1000rpm when it should keep max power all the way to 7300rpm!
Perhaps to hot and it not managing to add enough boost on top, or having to pull timing because of high IAT's? It would be nice to see the boost, IAT and timing logging for that run. Also be aware that if the numbers are corrected to SAE or similar, then that actually represents a double correction since the DME already had corrected for the "non SAE" conditions by adding boost... The S55's DME is programmed to add boost to compensate for high altitude and/or high temps. It does this in order to meet it's 425hp target no matter the conditions (within limits of course). That means that on the S55, you should see the same UNCORRECTED hp readings both on a cold and hot day (but with different boost). But if the dyno operator chooses to use the dynos SAE correction you will not get any correction if the conditions where the same as per SAE, but a large correction on a hot day... But the engine made exactly the same HP in real life on both days, because it had adapted and corrected (by adding boost on the hot day) already by itself, unlike any NA engine and most other turbo engines. This makes dynoing the S55 a bit different because ideally boost, IAT and timing should be datalogged to see if it corrects for conditions by adding boost. And since the S55 already corrects for conditions, adding SAE correction on top of that would be a "double dipping" and gives inflated numbers... Don't get me wrong. This takes nothing away from the performance of your car! It's just a general comment on caution being needed when dynoing these cars as regards SAE correction (and why we are seeing inflated numbers compared to BMW claimed numbers). If we see 1/4 mile trap speeds consistently at 120+ MPH, then I would say 400+ WHP probably is correct (and BMW having under stated the numbers). If we see the trap speeds we have so far, then it's just around within 5% of factory numbers IMO (taking into consideration the significantly higher average HP in each gear under acceleration due to the flat power plateau of the S55 compared to any NA engine). |
08-10-2014, 07:01 AM | #13 |
Croatian
884
Rep 3,613
Drives: PORSCHE
Beast
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only) Husqvarna FS450 (track only) Looking for an SUV |
08-10-2014, 02:56 PM | #14 |
5457
Rep 7,037
After my most spirited drive to date in my F80 ( close to broken in ) today. About 4h through the Italian, Swiss and Austrians alps with numerous Stelvio like serpentine roads and open roads mixed with traffic where I probably overtook ~ 50 times to me the car feels like a close to 500 hp ( crank rated ) car from my butt dyno. It doesn't have nearly the top end drama of the S65 but it passes cars like a bullet and pin my wife nicely to the seat. It feels wayyyyyy stronger than for example the N63TU at 440 hp, wayyyyyyy stronger. Sure the lower weight and the LSD contributes but g'damn it pulls hard from down low. Modest P-cars disappear quickly in the rear view mirror during acceleration... The car feel big though, and I really wish the steering was more communicative. It's the one thing that I miss more than the S65.
It is a bit of beast for sure. Very impressive power and I had genuinely fun today, something the F10 for example wasn't able to be on the same/similar roads. The suspension is great. Last edited by solstice; 08-10-2014 at 03:06 PM.. |
08-10-2014, 03:24 PM | #16 | |
1792
Rep 2,995
Nice review on the power. I will add that you are getting alot more effective wheel torque through the gearing on the S55/M3 than the N63TU and how that car was geared. One of my biggest lessons was that the e39 m5's S62 was an absolutely amazing engine. The beast. But it was connected to some rather tall gearing and a 3.15 final drive ratio, moderating it's feeling of acceleration quite significantly. |
08-10-2014, 03:39 PM | #17 | |
5457
Rep 7,037
08-10-2014, 03:50 PM | #18 | |
1712
Rep 5,109
And what you say about the car feeling like it's +400whp... That's what counts!!! (well empirically obtained data counts was well...) You could say that in a way it doesn't matter if it has 300 or 400whp. As long as it pulls like you have experienced and puts a smile on your face, then that's what you feel and experience. That's what matters the most! |
08-10-2014, 03:58 PM | #19 | |
5457
Rep 7,037
08-10-2014, 04:16 PM | #20 |
1792
Rep 2,995
08-10-2014, 07:38 PM | #21 | |
112
Rep 969
