Slight shudder on braking !
08-08-2014, 11:48 AM | #1 |
111
Rep 716
I'm getting a slight shudder when braking from 70mph or over. I know it's not a warped rotor as I changed all rotors and pads a few months back.
Any ideas what could cause this ? It only happens if I'm going 70mph or more then applying brakes, slight shudder then once I go below 70mph or release the brakes it stops completely.
BMW 325i M sport - Custom stainless exhaust ( 335i set up ) - Piano black interior trim - Gloss black kidney grills - Ferric grey 18" MV3 alloys -
08-08-2014, 11:54 AM | #2 |
1103
Rep 7,063
Control arms?
I hope that 70mph is legal
E90 Build Thread (SOLD) http://www.e90post.com/forums/showthread.php?t=809436
F15 Build Thread (SOLD) http://f15.bimmerpost.com/forums/sho....php?t=1064084 |
08-08-2014, 02:43 PM | #3 |
18
Rep 116
Rotors don't warp except in very few, select applications such as racing or towing extreme weight. It's misinformation, and often the reason why people don't understand it happening to a new set of brakes. What we consider "warped" is really an uneven transfer of braking material to the surface of the rotor, causing pulsation under load. Did you bed your brakes in properly when you got new rotors and pads? Have you recently sat at a stop light with the brakes depressed after a hard run with really hot discs? New or not, that could have caused it if you have uneven material build up on your rotors.
The best thing to do is probably get the rotors resurfaced if you check other components and can eliminate the control arm issue as Taran said. Don't believe me? http://www.stoptech.com/technical-su...nd-other-myths Last edited by Nati0n; 08-08-2014 at 02:53 PM.. |
08-08-2014, 02:51 PM | #4 | |
37
Rep 199
08-08-2014, 02:55 PM | #5 |
111
Rep 716
Yeah brakes where bedded in properly I'm thinking it's more likely to be the control arm as the brakes only have around 1500 miles on them
I had this problem with my old e90 (320d) changed the front rotors + pads problem solved. However the shudder was more severe and at all speeds upon braking
08-08-2014, 02:56 PM | #6 |
18
Rep 116
Do you have any strange noises associated with it? Does it happen more in the cold? Definitely possible it could be the control arms, or some suspension bushings or such.
The crux from StopTech to save you guys some reading by the way if anyone is interested: "...in more than 40 years of professional racing, including the Shelby/Ford GT 40s – one of the most intense brake development program in history - I have never seen a warped brake disc... In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. This uneven deposition results in thickness variation (TV) or run-out due to hot spotting that occurred at elevated temperatures." |
08-08-2014, 04:13 PM | #8 |
18
Rep 116
^I would think a flat spot or tire depth variation would be apparent at that speed whether braking or not, and he's describing it just under braking.
08-09-2014, 09:32 AM | #10 |
111
Rep 716
Is there any other way to check this manually ? Like shaking each wheel to check for play ?
08-09-2014, 10:07 AM | #11 |
General
17365
Rep 18,765
