08-07-2014, 07:49 PM | #1 |
146
Rep 165
M Sport Steering Wheel not level
Hey guys, have a 2014 328i M Sport with about 2K miles on it. Bought it new but the weird thing is that the steering wheel is not level across when going straight on the road. It isn't the pitch in the road and when it's level, I am veering to the right. It is just plain not level across from left to right when driving straight. Really bugs my OCD and shouldn't be the case in a BMW.
Anyone experience this and/or a solution in the F30? Thanks in advance! |
08-07-2014, 08:44 PM | #3 | |
146
Rep 165
08-07-2014, 08:47 PM | #4 |
1538
Rep 3,331
Was it like that when you bought the car?
You need an alignment. If it was like that when you got the car you should have never taken delivery, or go back and ask the dealer to fix it. If you don't recall when it happened, it's possible/likely at some point you (or possibly someone else driving your car?) hit something hard enough to crook it over. The only other option is make sure your tire pressures aren't extremely off balance, but the TPMS would likely alert you if it was that bad.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
08-07-2014, 09:01 PM | #5 | |
146
Rep 165
I assume this shouldn't be a big issue for them and they can fix. I know it isn't the tires - I checked psi already. Thanks guys |
08-08-2014, 07:39 AM | #6 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
You could have a bad tire - internal belt separation or something akin to that. Look at the tread and see if it's wearing unevenly or "cupping". Sounds more like alignment, though. And yes, you don't own a Toyota - you can trust the dealership not to scratch your wheels, and even if they did, they'd take care of fixing them.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
08-08-2014, 08:22 PM | #8 |
Rep 7
I am having the same issue with my new 335i and told the dealership that I noticed it on my way home from the dealer. They have done an alignment (wheels were aligned already but steering wheel off), at no cost to me and acknowledged that the steering wheel was off and should now be fixed.
It is not fixed. I will be bringing it back in, as the service manager wants to go on a test drive with me to see it first hand. It seems from our discussion that they will do what is needed to get this resolved and believe that the steering wheel came misaligned from the factory and is not serious but more of an annoyance. |
08-08-2014, 09:37 PM | #9 |
890
Rep 7,047
08-09-2014, 05:40 AM | #10 |
Human
932
Rep 1,200
I have the same issue since I got the car...
Alignment was checked some time ago but that didn't fix it. Now that my car is in the shop, they said they re-did it and should be fine now. I'll update you when I get it back...
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album 2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album |
08-30-2014, 08:14 PM | #11 | |
146
Rep 165
09-18-2014, 06:02 PM | #12 |
146
Rep 165
Guys, I just don't trust taking it an hour to the dealer to do a half-a$$ solution and find it wasn't fixed. I have seen the DIYs to remove steering wheel. Question is, are the threads on the steering wheel designed to allow this or can it only go on one way - is there some sort of pattern that would prevent me from aligning it myself? It looks simple. Thanks in advance!
09-19-2014, 01:44 AM | #13 | |
Human
932
Rep 1,200
So just to make sure, are you 100% positive it was your steering wheel? I'm asking because I've been to the shop 3-4 times with the car having the same issues that you had. The first time, the steering wheel was indeed a tiny bit off, but that was not the reason why it was veering to the right. There were two more unsuccessful attempts at doing a proper alignment, but nothing changed after each "repair". I finally took the service manager for a drive and presented in no uncertain terms that this was a shitty job. They took the car again, this time to an "outside" garage which had more precise alignment tools. This time, everything was a lot better... Given the relatively wide tires (225 front /255 rear) the car still follows the road crown, but now you can see that if you go in the middle of the road it will go straight. If I were you, I'd go in for an alignment check and ask if they have a laser based alignment tool.
09-19-2014, 07:38 AM | #14 | |
Too much is never enough
655
Rep 3,079
It's not their equipment that's the problem, it's their techs. I can align a car perfectly, the first time, with string and chalk. For anyone considering it, don't try removing your wheel to correct the problem. Have the dealer make the adjustment and be sure to tell them the issue is the STEERING WHEEL alignment so they actually pay specific attention to it. Otherwise the tech will simply see "alignment" on the work order and sign off that it's fine when he puts it on the rack and indeed sees that everything is in spec. |
09-19-2014, 07:41 AM | #15 |
Rep 205
Drives: 2014 335xi MSport
Thanks for the tip.
Ive been needing to get this done ever since I took delivery, just havent gotten around to it yet.
2014 335i xdrive MSport AW/CR, SAT, Prem, Tech, HK, DHP, MPPK, MPE, NWA, KMFDM, etc... |
09-19-2014, 07:55 AM | #16 |
Human
932
Rep 1,200
Entirely possible
09-19-2014, 02:02 PM | #17 | |
118
Rep 1,668
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
09-19-2014, 04:18 PM | #18 |
146
Rep 165
Thanks all. From what I understand, the F30 steering wheel can only be installed in one position so it requires an alignment. I shouldn't have ignored it this long. Thing that sucks is the car is 5 months old and has 2800 miles, and they would have covered this under the warranty up to 2K miles.
