08-02-2014, 08:03 PM | #1 |
73
Rep 495
Tire Pressure for the track
I always bump up the PSI for the track to stiffen up the sidewall. What PSI do you run tires at when your on the track?
08-03-2014, 09:00 AM | #2 | |
1231
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
If anything I would let air out at the start of your track day. My guess with the weight of the F8X is maybe start the day with 32 psi all around and check the pressures as soon as you come off your first session. It might be around 36 after the session, and the 4 tires can vary depending on what type of track (left vs right), how aggressive you're driving, and how much understeer / oversteer your experiencing, and how hot it is that day. |
08-03-2014, 11:59 AM | #3 |
32
Rep 111
Yes, bumping up tire pressures is incorrect. In addition to what MaynardZed said above, you want softer sidewalls to increase grip.
I usually start at 32 psi cold for the first morning run and I check my pressures immediately after each run. Throughout the day I am constantly taking out air until the air/track temps start dropping. Usually last run of the day I have to add a couple psi all around. |
08-03-2014, 07:10 PM | #4 |
1903
Rep 5,678
I always start 5 to 6 psi less than normal and then gauge from there. To me, it's all about measuring sidewall rollover. Too much rollover and you increase pressure. None at all (that is, wear is not coming to the outer edge of the tread) or the car feels too unstable and I lower it a bit. If you are a baller and have a pyrometer to measure temp across the tread that's even better. Given the F82 is 32 psi, I will like start with 28 and see where that ends up and adjust from there.
Going above the normal street pressure that will only result in too much centre wear, less traction and a car that is way too darty.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
08-03-2014, 08:52 PM | #6 |
26
Rep 130
For track use, Donnie Isley, instructor at the Performance Center, recommends keeping the F80/82 (hot) tire pressures below 36 psi at all times. One of his colleagues suggested starting at 29(f) and 31(r) psi.
M4_Snell11.50 FrankMstein1018.00 |
08-04-2014, 11:24 AM | #10 |
BMW Fanatic
374
Rep 1,413
Drives: 2020 X3 M
When I was on the track here in Austin driving a 458 Italia the tire pressure light was on. I showed it to the instructor and he said that they take air out of the tires for track racing and that's why there's a warning.
SteveSpy
Current Ride: 2020 X3 M |
05-22-2016, 08:00 AM | #11 |
17
Rep 32
Given that this thread is nearly 2 years old I figured there might be some more experience with the F80 on track. What are folks using for starting and target hot temps with the stock MPSS?
I just completed my first track event with this car and started at 31 all the way around but the fronts were up to 48 PSI before the first session was over so I started dropping pressures. I ended up dropping to around 26 PSI starting pressures which is typically where we start the Corvettes on MPSS run flats. That usually brought me in the 32-26 PSI hot pressures but saw a ton of sidewall roll-over and corded the outer edge of the front tires in 2 days. Since this isn't my primary track car I plan on sticking with the MPSS when I go to the track but can't afford to run through a set of fronts in a weekend. Should I just start at 32 PSI and deal with the high pressures and lack of grip? I surprised both by how much the pressure climbed in this car and how much the sidewall rolled over. |
05-23-2016, 10:35 AM | #13 |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
I posted this here, but thought I'd share since this thread aligns with my experience.
I've been experimenting with this for my upcoming road trip as well as daily driving and track days. This is the method I follow:
Ultimately, you would want to balance the tire pressure so that when the vehicle is under load, the tire air pressure remains as equal as possible. For instance, my current set up is the following. This allows room for extreme cases (long road trips, spirited driving, etc.) were the tires are building heat and the air pressure rises to remain under or at the 51psi max pressure recommended by the Continental Tires. Right front tire: 47.6psi Right rear tire: 47.3 Left front tire: 47.9psi Left rear tire: 47.6 Looking at these values you can see that when my M3 is at load the tire pressure remains pretty equal with the lowest value (right rear) 0.3psi under the average value versus the highest tire pressure (front left) at 0.3psi over the average. The added weight from the driver (myself) accounts for the variance. Some fine tuning might bring these values even closer. **These examples are based on an F80 M3 with a driver at 5'10, 165lbs. Full tank of gas, and no other cargo. Wheels are 19" with OEM Continental Tires. Your experience may vary.
/// M3 |
05-23-2016, 05:12 PM | #14 |
17
Rep 32
10-15-2022, 04:48 PM | #15 | |
244
Rep 356
