BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > DDE replacement under warranty
      07-31-2014, 05:45 PM   #1
GottaBeKD
GottaBeKD's Avatar
136
Drives: 335d
In our never ending quest for data and statistics.
If you had your DDE replaced under warranty. What was the year and build date of the vehicle? Hoping to see a pattern.
I have since had all 6 injectors changed a month ago and the car is in the shop right now getting an injector replaced.
Mine is an 11. Will get the build date when I get it back from BMW.
      07-31-2014, 05:57 PM   #2
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
Never had this issue but my car is a 2009 and has the "Bosch EDC CP09" DDE version.
I've heard that at some point they switched over to a Siemens DDE version.
      08-01-2014, 07:10 AM   #3
chau
chau's Avatar
28
Drives: 335d
I had my ECU replaced 2 weeks ago under my extended warranty. 76,000 miles and all 6 injectors were replaced last year.
edit: 2010 with a 09/2009 build date.
      08-01-2014, 07:19 AM   #4
Mark M
Mark M's Avatar
240
Drives: E30M3 E83X3 E90335D
Yes, DDE was replaced under original 50k mile warranty. Even after carbon cleaning and 6 new injectors the car was continually throwing zero quantitiy adaption codes. I provided my SA with the Service Bulletin that cited new DDE was the solve. They then ordered one, programmed it and off I went.
      08-01-2014, 12:53 PM   #5
GreekboyD
411
What year is your 335d?
      08-01-2014, 12:56 PM   #6
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
wow Mark it YOU to convince them thats sucks!!
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD
Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now)
      08-01-2014, 04:44 PM   #7
dzlmoose
dzlmoose's Avatar
Egypt
122
Drives: Trek 7.2, 2001 M5
My DDE is in transit hopefully.
My car is 2011MY and I think an 09/10 build.
I had:
2 injectors replaced
Then the Carbon cleaning
Then all 6 injectors replaced
Now it's DDE time, it's funny cause I told the SA when I dropped the car off the DDE is gonna get replaced.
      08-01-2014, 10:19 PM   #8
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
Dzl, how many miles are you at?
      08-02-2014, 10:44 AM   #9
nuclearbeef
Drives: 2010 335d
2010, 82k miles.
Just had carbon blasted, and the next week had all six injectors replaced.
Getting it back Monday, if it doesn't throw any more codes while the tech is driving it this weekend.
I can't find the service bulletin for DDE replacement.
I'd like to be able to show it to the SA if mine keeps throwing codes.
Anyone know the # of the bulletin?
      08-02-2014, 11:02 AM   #10
gtp900
gtp900's Avatar
39
Drives: 2011 BMW 335D, 2015 35d mspor
How much does this cost if your out of warranty? (DDE replacement)
Worried about this...
      08-02-2014, 09:13 PM   #11
Big_Daddy_38
Drives: 2011 335d
2011 BMW 335d  [0.00]
My DDE was replaced under original warranty at about 48000 miles. The car is an April 2011 build. It was replaced after carbon clean up and rough low load performance with accompanying check engine light.
      08-03-2014, 01:38 AM   #12
dzlmoose
dzlmoose's Avatar
Egypt
122
74,000 km
46,000 miles
      09-11-2014, 07:43 PM   #13
msowka
Drives: 2010 335d
I had:
Moose, which BMW Service (in TO?) did you get this done, and what is the ID of the service bulletin for Siemens DDE? Thanks
      09-11-2014, 08:42 PM   #14
GottaBeKD
GottaBeKD's Avatar
136
Drives: 335d
I'm now getting a new DDE. Gotta hook up with one of the Toronto boys and read the old version and new when I get it.
      09-11-2014, 11:19 PM   #15
135i_vs_
135i_vs_'s Avatar
72
Drives: M5, 135i, 335d, F10 550xi
I hope this thread will help you. Latest DDE part number on the invoice.http://www.e90post.com/forums/showthread.php?t=838287
      10-01-2014, 07:23 AM   #16
GottaBeKD
GottaBeKD's Avatar
136
Drives: 335d
So quick update on my car.
I got a new DDE installed and quickly racked up 2500 kms over the last 3 weeks.
So far no more faults. I'll be a lot more comfortable when I hit 5k without a fault but for now pretty happy.
Only mod right now is a catch can and BMW did not say a thing about it during the multiple service visits.
      10-01-2014, 08:35 AM   #17
Mark M
Mark M's Avatar
240
You should be good-to-go. It has been ~14k miles since I've had Carbon cleaning and a new DDE. I have had zero faults.
      10-01-2014, 08:51 AM   #18
GottaBeKD
GottaBeKD's Avatar
136
Drives: 335d
No carbon cleaning for me. They said it was not bad
      10-04-2014, 09:14 PM   #19
9mmkungfu
198
Drives: 335d, 535d, 750i, X5 35d
Can you provide the service bulletin number for the DDE issue?
