07-30-2014, 07:58 AM | #3 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
What exactly does that mean? It was as clean a diesel as any. The X3 now has a 300-hp 6-cylinder diesel option, very likely the same engine as they'd put in a 3-series for a 335d. If they'd had that engine option back when I ordered my 335i in Dec. of 2012, I would have ordered it instead of the gas engine.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
07-30-2014, 08:09 AM | #4 |
253
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
I think it's plenty clean but there isn't enough of a market for it. The majority of the diesel market is looking for an economical car with plenty of torque, and the 28d has that. The 35d really didn't get that great of mileage, especially compared with the N55.
07-31-2014, 01:29 PM | #5 | |
16
Rep 243
Drives: 2013 335i M-sport
2. The fact most Americans are either ignorant of or uninterested in performance diesels. 3.The fact that most Americans buying a sports sedan are unwilling to pay more for the diesel 3 liter then the 3 liter gaser. 1. and the money BMW would spend to get the N57D EPA emissions approved for the F30, when there probably isn't a profit in selling that car in the US anyway. Last edited by v1k1ng01; 07-31-2014 at 01:37 PM.. |
07-31-2014, 01:41 PM | #6 |
Curmudgeon and Pedant
690
Rep 3,489
I suspect you're quoting a UK mileage, with their larger gallon. The US/CA 328d (320d EU) is rated at 43-45 mpg highway, so I seriously question that a 335d would get 48. The US/CA E90 335d was rated at only 36 mpg highway.
Last edited by floydarogers; 07-31-2014 at 04:19 PM.. Reason: 43 mpg is what an xDrive gets - I had mis-typed 23 |
07-31-2014, 01:59 PM | #7 | |
16
Rep 243
The EPA requirements for DFP's and EGR's were responsible for a 10% to 15% drop on power and fuel efficiency across the board on all Diesel vehicles in 2004, whereas Bluetec gets rid of all that junk. There a lot of information about this on the TDIclub forms. |
07-31-2014, 02:58 PM | #8 |
Rep 54
The engine used for the 335d is currently EPA approved for the 535d in the US, so this isn't necessarily a regulation issue.
The only reason they don't have a 335d in the F30 is they don't want one. That's all. |
07-31-2014, 04:09 PM | #9 |
16
Rep 243
A lot of folks said that about the Golf GTD since it's engine is shared in other VW and other VW Audi models sold in the US. Turns out that was only part of the story. If BMW thought there was money to be made on selling a 335d in the US they would. Fact is that there's a lot of red tape to cross to make selling this car worth it. Same story for other European car manufactures as well when it comes to diesels.
07-31-2014, 04:18 PM | #10 | |
690
Rep 3,489
All the 335d E90 cars in the USA/CA have a DPF, which includes an Oxidation Catalyst. They also all have the Selective Catalytic Reduction (SCR) system (which uses Diesel Exhaust Fluid - DEF), which is what you mean when you say "Bluetec", which is a trademarked name not used by BMW. We (in the US/CA) are pretty certain that BMW used our 10,000 335d cars (and the X5d) as a test site for their rollout of the SCR system there in the EU. It's quite possible that the newer N57 with SCR is a bit more robust and efficient than the systems on our M57 engines, but come on, it's not going to take a 36 mpg car up to 48 mpg. |
07-31-2014, 04:33 PM | #11 | |
317
Rep 3,619
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
07-31-2014, 04:55 PM | #12 | |
16
Rep 243
Simply removing a DFP and a EGR from can account for the power and fuel economy gain. The fact that it's a newer engine design with a different turbo set-up is just icing on the cake. If you look at the fuel economy figure for other similar diesel engines not sold in the states that use this tech you would see a trend. Even if you convert the mpg number assuming the economy is rated UK to US that's still 40mpg US, which is 10 mpg (25%) better then 335i. Last edited by v1k1ng01; 07-31-2014 at 05:15 PM.. |
07-31-2014, 06:40 PM | #13 |
253
Rep 1,003
This. I believe each engine-chassis combination has to be crash tested and go through the whole certification process in order to be sold, so it's not just a matter of the engine being accepted by virtue of the 535d.
07-31-2014, 06:43 PM | #14 | |
24
Rep 196
The DPF and a new NSC are combined into one unit, but EGR, seperate SCR catalyst, plus particulate matter sensor are also still required. |
07-31-2014, 06:50 PM | #15 | |
690
Rep 3,489
Not all EU cars have SCR. |
07-31-2014, 07:44 PM | #16 |
24
Rep 196
08-01-2014, 07:16 AM | #18 | |
1837
Rep 6,990
