07-28-2014, 09:42 PM | #1 |
2006 TIME Person Of The Year
9720
Rep 6,445
I wish I could remove SPORT mode via coding. I have no need for it, and thus no longer use that driving mode.
The problem is the stability control is way too intrusive in SPORT. I find the mode backing off power far too early when accelerating out of a corner. It's basically a waste of time to use this mode. Maybe I'm missing something? My personal reference for stability system performance derives from Porsche's I've driven. Their system intervenes pretty smoothly and allows a little rotation/slide/slip angle. To date, I compare all other systems to theirs. While not as sweet as Porsche's system, SPORT+ mode is at least useable. I still think SPORT+ could be more organic, and a bit less intrusive; especially as the most aggressive 'standard' driving mode! This is my quick go-to sporty driving mode when the unplanned occasion arises due to its relatively easy access. Now that I know my car; I learned that I really want (need?) to have all the stability control completely off for spirited driving. SPORT+ is still putting too much (read: any) damper on the fun... Plus I prefer the linear, non-SPORT throttle map the DSC OFF mode employs. Best yet, SPORT steering weight is still active in this mode. The problem is accessing what I will call this "alternate" driving mode is slow to enable, and requires the following: 1. Use driving mode switch to activate SPORT mode. 2. Hold down traction control switch (3 sec?) until DSC OFF mode activates. Note: Technically the vehicle is not in SPORT mode any longer. I submit: One press downward on the mode switch results ECO PRO mode. My idea of a more-perfect choice of 'standard' driving modes would be: DSC OFF SPORT+ COMFORT ECO PRO Just an observation...
07-28-2014, 10:19 PM | #2 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
An LSD helps a lot with reducing DTC (and DSC) intervention.
Ahead of the curve for specF30
07-28-2014, 10:25 PM | #3 |
404
Rep 962
If I'm in a sporty mood I always switch to Sport+ (and DS on the tranny ), never Sport. If Sport+ is enabled on a car, I don't see any reason to use the regular Sport mode either.
07-28-2014, 10:34 PM | #4 |
793
Rep 1,627
Compared to my e92 it seems that, in sport mode, the traction control nanny's are much less intrusive. With the being the case, I don't mid it so much. I use Sport in town/on the highway and sport + when I'm driving on a nice winding road. I have DHP, don't know if that makes a difference.
07-28-2014, 11:44 PM | #5 | |
124
Rep 704
Drives: 2014 328d
Turning off DSC when in Shockware's new Sport mode is really not very relevant for road driving--that's how good it is. I personally don't feel comfortable driving at 8/10ths+ on back roads in northeast Massachusetts. There's just too many people, driveways, and cars around--even on "back roads"--for me to relax, enjoy, and focus on driving. The only time I was really able to appreciate its benefits was in a controlled driving environment at a BMWCCA event.
2014 328d SportLine
07-29-2014, 07:06 AM | #6 | |
72
Rep 876
One thing to note, if you long press DSC Off from any mode (Eco, Comfy, Sport) you still get the same results. So no need to switch to Sport first and then long press DSC Off button. I just start the car (default in Comfy mode) and long press DSC Off before I even pull out of my garage. Still have firm suspension (DHP) and tighter steering and a nice linear throttle response, not artificial like Sport +. While I enjoy all nannies completely off as it allows me to have a little fun I will say at times the eLSD is pretty intrusive. No where near a mechanical setup in the way it engages, or the way it feels when it engages. The only time I run Sport + is when I want to hear the exhaust burble. I really wish I could get the same burble from DSC Off mode. That's probably my biggest gripe. |
07-29-2014, 08:10 AM | #7 | |
55
Rep 681
BMW M3 G80 Isle of Man
07-29-2014, 09:49 AM | #8 |
343
Rep 2,118
Maybe it's different with a 335 vs my 328 but unless the road is slippery or bumpy on a curve, I almost never have the nannies intrude. Maybe I don't drive as hard as you but my technique of smooth application of the throttle increasing through the turn is the fastest and smoothest method. If you are abruptly mashing the throttle, you are overloading the tires, causing them to loose traction and provoking the nannies.
07-29-2014, 10:03 AM | #9 | |
9720
Rep 6,445
Maybe the system is calibrated around the OEM run flat tires' traction profile and my Pilot Super Sports need a more aggressive stability control calibration?
07-29-2014, 10:56 AM | #10 |
Now in the dark side !
65
Rep 1,136
I do use the Sport mode as often as the Sport+, depends on the occasion.
Had a very slow driver in front of me until a light that allowed a 2-cars left turn. Did put my car in Sport+, then turned and mashed the throttle just a little too hard. Car slided too close to the other car for my comfort. Don't know if you all have xDrive cars, but on my RWD, I don't mind a little nanny once in a while...
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
07-29-2014, 11:26 AM | #11 | |
Rep 126
07-29-2014, 01:35 PM | #12 |
16
Rep 337
For my tastes, Sport is nice. But then again I hate the mushy steering feel in 'comfort'. So once the car's turned on, it goes into sport no matter how I'll be driving.
I'm still new to it so maybe I'll grow tired of it, but I think it's kinda cool to get in and toggle to a different mode. Feels like a preflight checklist! Then again, I like buttons/fiddling
2014 M Sport
//OEM+// |
07-29-2014, 02:18 PM | #13 | |
155
Rep 2,266
F30 Sapphire Black M-Sport 335i 6MT
07-29-2014, 03:00 PM | #14 |
3187
Rep 10,509
agreed OP, full off + mechanical LSD would be a nice option to have
that said, for the street I think sport+ is a nice compromise. Lets you get the car a bit sideways but provides a bit of safety net for unexpected things on the street (gravel, standing water, etc etx |
07-29-2014, 03:32 PM | #15 |
14035
Rep 10,080
I have an xDrive so it is not completely in line with what you RWD guys are talking about. But, I do like hitting Sport on the freeway or two lane roads for more passing power and than drop back in to Comfort for cruising.
I do like Sport + as well. Even in the xDrive version it lets you get a little bit squirrely. |
07-29-2014, 06:51 PM | #16 | |
9720
Rep 6,445
07-29-2014, 08:52 PM | #17 | |
3187
Rep 10,509
IMHO, you should get a sportier car that doesn't make many street compromises or start modifying to remove those compromises. Last edited by nicknaz; 07-29-2014 at 09:00 PM.. |
07-29-2014, 09:54 PM | #18 | |
9720
Rep 6,445
This is actually a significant improvement! Now DSC OFF mode is enabled with only one switch. It may take a long press, but at least I'm not expected to be feeling around for two different buttons.
07-29-2014, 10:51 PM | #19 |
558
Rep 1,477
Drives: 335i
I've been back and forth on this subject a bit over the last six months or so... but at this point, I actually think Sport+ is less useful than Sport or DSC-off. Here's my take on each:
DSC-off/eLSD: Minimal nannies (especially when paired with a mechanical LSD ; ) Great for AutoX, or a track you're comfortable on when you know what you're doing... or for "exploring the friction circle limits" on your favorite roads. Sport+: Allows for slip angles and a little wheel spin before cutting engine power. There's no actual "stability control" activity in this mode, so from my experience it really doesn't give you any safety net advantages above the eLSD function in DSC-off. It does have the sharper throttle mapping, lack of kick-down switch, and faster auto shifts than DSC-off if you're not using the paddles... none of which are really needed for performance driving IMO. Sport: Leaves DSC on, so full stability control functionality is retained for times when you're not in full attack mode..e.g. bad weather, or when you're just driving without much of any sporting intent. Steering settings (and chassis settings for those of us with DHP) can be configured for either "Comfort" or "Sport". Personally, this is my standard go-to mode whenever I start the car, usually with chassis set to Sport, driveline set to Normal. (I always use paddle shifters anyway, so auto shift speed doesn't really matter to me.) For daily driving I don't usually find it to be too invasive - especially since getting an LSD. Comfort mode I only engage briefly, for the benefit of softer damper settings, on bumpy roads... and EcoPro mode is really more of a novelty.
07-29-2014, 11:30 PM | #20 |
14
Rep 110
Perhaps I'm just too new to my car but, I find regardless of the mode the car feels big. I love the power and sound of the engine but in turns I can't help but notice how the car is kind of lazy. I don't really have any other words to describe it.
Overall here's my break down of the modes ECO: It's great for those slow days but I likewise find issue in that in any emergency scenario the car will scoot slower than a mini van. Comfort: IMHO this gives the car the most natural feel. The steering doesn't feel un-necessarily heavy and the throttle doesn't feel like a sprint booster is attatched. Only issue is the steering does feel slightly numbed a bit. Sport/Sport+: I feel this just tries to give the car a sporty feeling at the cost of being very artificial. The throttle response becomes overly touchy and the steering becomes too heavy. Perhaps I haven't experimented with the car very much but I honestly still prefer the way my mk6 drives. Apart from the lack of umph, sound, and slight extra cabin refinement; I feel my mk6 drives more naturally. Though I listed the same issues with my mk6 when I just bought it lol Last edited by M-Powa!; 07-29-2014 at 11:40 PM.. |
07-30-2014, 06:43 AM | #21 |
55
Rep 681
According to me, there's a relevant different in handling between F30/31 and F32: the front-wheels of the latter is stiffer and more precise and reactive.
Moreover, the riduced height limits the roll. Those are my impressions after driving both F30 and F32 on track. Remember that the front suspensions of F32 have wider camber and caster angles than F30/31. Said that, I prefer the heaviness of the steering in Sport/Sport+/DSC Off mode than in Confort, while I appreciate more the soft throttle response in DSC Off. For me Sport mode is the less useful, while the program I use more often on my Dolomites streets is Sport+ I use DSC Off only in same circumstances (in case of good way outs...) and always on track.
07-30-2014, 09:41 AM | #22 | |
17
Rep 123
because the traction from the super sport is a lot better.. the super sport really shines in DSC off mode sorry to leave the main topic i prefer the DSC off for really sport driving when im alone on the streets and no cars near me ;D but while im near some cars i go for SPORT and SPORT + for safety reasons |
