07-28-2014, 03:16 PM | #1 |
199
Rep 1,114
Does the Auto Vent Feature work well?
I read in the Owner's Manual (Yes I downloaded the Owner's Manual Before I have received the Vehicle) that there is an Auto Venting Feature that can be set on a Timer or Temperature to Vent the Car of Hot Air when Parked in the Sun Too long.
Has anyone tried this feature?
My Ride! : 2015 428i GC (F36) - MSport, Alpine, Black Leather, MBrakes, Adaptive, Sport Seats, Hex. Alum w/Piano, HK Sound, 400m's, Comfort Acc. When I’m not Driving: https://youtube.com/shorts/ViKD_Hj5htE?feature=share
07-28-2014, 03:42 PM | #2 |
Rep 39
I've used it, but it would be better if the schedule would repeat. It needs to be activated everyday. Also, it would be better if you could schedule how long it will be on for (30 mins seems a little long).
Basically, I use it if I know its going to be very hot and I'll set it for 15 mins before I think I'm going to leave work... Takes some of the heat out. |
07-28-2014, 03:47 PM | #3 | |
199
Rep 1,114
It seems like a pretty neat feature!
07-28-2014, 04:38 PM | #4 | |
29
Rep 784
AC doesn't come on - that would drain the battery to much. When it's ~100+ deg outside, car gets even hotter with windows up so this equalizes things from what would be 120-130. I set mine for ~15 min before I usually leave so even if I am late it does do some good. I use a sunshade and normally open the sunroof to help vent as well if I am pretty sure there won't be a thunderstorm. This in combo with the ventilation does a decent job. I have setup a memory button to take be to the screen to activate my preset timer, so all I have to do is hit the preset and push in the iDrive to activate the default timer. |
07-28-2014, 04:43 PM | #5 |
772
Rep 1,502
I've used it a couple times. The problem for me is I don't generally know when I'm getting back to the car, so setting it up isn't worth the effort. If it's controllable through the remote app that would be more useful (I don't have the remote app feature).
I just use my remote to roll all the windows down while I'm walking up to the car. I kinda figure that'll work as well if not better than setting up the vent. |
07-28-2014, 04:45 PM | #6 |
171
Rep 688
I love the feature.... when I remember to set it. Which I forget to do about 50% of the time.
2014 Carbon Black 535i M Sport - Bootmod3 / M Performance Exhaust / Carbon Graphite Vorsteiner V-FF 103 / KW V2
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot |
07-28-2014, 05:12 PM | #7 | |
Prince of Zamunda
Rep 310
07-28-2014, 06:38 PM | #8 | |
199
Rep 1,114
07-28-2014, 06:47 PM | #9 |
31
Rep 1,917
I use it frequently. It helps a bit for sure. It is also available via the MyBMW app so if I forget to set it I can do it remotely as well.
2014 EBII 435i xDrive M-sport
Gone: 2011 TiAg F25 X3 xDrive35i M-sport Gone: 2008 TiAg w/Coral Red E88 135i Cab M-sport |
07-28-2014, 07:02 PM | #10 |
138
Rep 690
Did anybody ever find out why this feature (activate vent via iPhone app) is not available in the US? Which regulation/law does it contravene?
07-28-2014, 07:48 PM | #11 |
14
Rep 86
07-29-2014, 07:13 AM | #12 |
72
Rep 876
I too use this feature daily. Like pcbrew, I set #8 button to shortcut to the screen. I turn it on each morning on the drive into work. I also use both time slots, 1 for lunch time and one for quitting time. Works pretty good. On the really hot days I also long press my unlock button so all windows roll down as I am walking up to the vehicle.
07-29-2014, 07:48 AM | #13 |
34
Rep 141
In the winter time, is there any benefits to this app? If it only circulates outside air, I take it that I won't heat it?
2014 BMW 435i xDrive M-Sport "Elphie" | Mineral Grey Metallic | Coral Red Interior | M Performance Package I | Premium Package | ConnectedDrive | bootmod3 OTS Stage 1 93 Octane Tune | M Performance Exhaust | M Performance Stainless Steel Pedal Covers | Dinan Performance Spring Set | Dinan Supplemental Ride Quality | Precision Raceworks N55 Ignition Kit
07-29-2014, 09:02 AM | #14 |
23
Rep 169
There is no benefit in winter time since your car will generally stay slightly warmer than the outside. The only advantage I can think of is it would bring some fresh outside air in, but you'll get that just from opening the door and also from using the climate system as long as you don't set it to re-circulate.
07-29-2014, 09:36 AM | #15 |
38
Rep 378
I'd rather have the Residual Heat feature instead of this
2022 Audi RS5 Sportback
SOLD 2013 BMW 335i M Sport Xdrive / MPPK / MPE / Alpine White / Black Dakota Leather / M Sport Brake / 19"Style 403m / M Perf Diffuser |
07-29-2014, 10:18 AM | #17 |
72
Rep 876
07-29-2014, 10:44 AM | #18 |
772
Rep 1,502
07-29-2014, 11:55 AM | #19 | |
304
Rep 1,739
And I don't believe there is any regulation preventing this from being added to the iOS app. It just sucks and needs an update. The newly released Android app on the US Play Store has this feature. |
07-29-2014, 01:37 PM | #20 |
138
Rep 690
Thanks Fronzdan another great tip I'll check out! I used your other tip about using Google Maps/Send to Car for Nav destinations from my iPhone and it works great, much better than the BNW iOS app!
07-29-2014, 01:40 PM | #21 |
118
Rep 1,668
I have used the timer part of it and it does take some of the heat out of the car if remember to set it. I see where there is a temperature setting too but it is greyed out so I cannot use that for what ever reason. If anyone knows why it is greyed out i will certainly appreciate it.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
07-29-2014, 01:42 PM | #22 |
138
Rep 690
What's the name of the app on the Play store?
