Reduced mpg as a result of new red charge hose
07-25-2014, 06:38 AM | #1 |
240
Rep 1,288
Over the last couple days my commute trip mpg has been down ~8% = 4 to 5 mpg. This is right after having the dealer replace the leaking red charge hose with new including seals.
Trip is ~75 miles mostly highway. Zero rain. Zero to no wind. Temps in 70s to 80s. Observations: - Cruise control at a steady 77mph - Tires are at correct pressure - Per OBD monitor, Engine coolant temp remains 78 to 80 degrees C (normal) - Per OBD monitor, Engine load ranges from 27% to 50% (seems high for steady interstate cruising) - Per OBD monitor, Fuel usage ranges from 4.5 to 10 liters per hour (seems high for steady interstate cruising) - Per OBD monitor, EGR is being commanded thus car is not doing a DPF regen - Car’s instantaneous mpg gauge is also showing down as well, dipping into the teens on uphill stretches - Car has had full carbon clean up 10k miles ago and ever since EGR has been blocked off. - Slight diesel smell upon shutdown in garage. Thoughts? TDI, I heard you get paid in beer for armchair diagnosis? Could there be a hose or sensor that was mishandled during the charge pipe replacement that would result in this decline in mpg? |
07-25-2014, 06:41 AM | #2 |
229
Rep 3,489
Drives: Montego Blue 335d
How can that be something else is wrong here
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
07-25-2014, 07:23 AM | #3 |
614
Rep 2,410
Wow, that's a huge change... Did they by chance re-flash your DDE when you were there? Or did they reset adaptations (BMW documentation calls for reseting fueling adaptations after messing with things in the intake or fueling ... see attached)?
If they did either of those two things then your car could be settling into a whole new fueling configuration/calibration. Is it possible there's a loose connection somewhere around the areas they were fussing with? Can you log requested boost and actual boost? That could show an air leak in the intake if there is one. Sure others can chime in with more thoughts, but that's my arm-chair-for-beer thoughts this morning.
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
07-25-2014, 07:26 AM | #4 |
229
Rep 3,489
TDi I believe they did both cause remember last time i lost my Flash a while ago, I inquire about this and they told me that they were directed to reflash cars anytime they felt like it, which didnt make sense to me but thats the way they operate
07-25-2014, 07:29 AM | #5 |
870
Rep 2,615
If you are leaking boost your mpg will drop. Make sure that the connections between the red charge hose are secure. Check turbo outlet and intercooler inlet. Especially the last one. It could have popped off. But for that drop in mpg you should hear hissing of pressurized air. Hope they did not re flash you. Did they know about EGR block?
07-25-2014, 08:29 AM | #6 |
240
Rep 1,288
The paperwork makes no mention of reflashing the DDE or resetting adaption. Paperwork only cites changing the parts.
Also, the car feels strong, no lack of punch. |
07-25-2014, 12:37 PM | #8 | |
614
Rep 2,410
Not sure what else to suggest at this time. Please keep us posted with how this evolves. And good luck figuring it out.
07-25-2014, 05:13 PM | #9 | |
Rep 62
2011 335d, JBD, AEM Meth Kit, Sport Steering Wheel Retrofit, Eibach Pro Kit, Koni Sports, 162 Rims.
07-25-2014, 05:19 PM | #10 |
171
Rep 504
07-25-2014, 06:44 PM | #11 | |
614
Rep 2,410
I've never seen a regen in process that has the EGR at any other position than 0%.
07-26-2014, 03:05 PM | #12 |
Rep 62
Oh, woops.
07-27-2014, 06:43 AM | #14 | |
614
Rep 2,410
This is data from when the car was less than a year old and comparing coolant temp behavior during drives to work when a DPF was being commanded vs no regen.
07-27-2014, 08:29 AM | #15 |
240
Rep 1,288
Took the family on a 170 mile round trip yesterday. Obc reported 30.3 mpg. But on the return I filled up the tank. 477 miles yielded 34.13 hand calculated mpg. Better than I was expecting.
My loose theory is that perhaps the DDE correction values for mpg calculation could be off. Recall back in March I adjusted this correction factor as the car was consistently reporting higher mpg than what was being shown by hand. Now it seems it is reporting lower than hand calculations. Could a leaking red charge hose result in optimistic obc mpg which I masked with a correction factor adjustment? Or perhaps the dealer recently did some DDE reset. Going to track it over the next tank of fuel to assess further. But initially pleased to see hand calcs show mpg greater than obc calcs. The car definitely feels better with the new charge hose. Instant response off throttle. |
07-27-2014, 10:41 PM | #16 | |
363
Rep 317
Do you have data comparing temp with the EGR open versus blocked? Blocking should definitely raise head temps but at the same time eliminate EGR cooler demand. I'm curious to see how this modification impacts the cooling system and exhaust temps. -Mike |
07-28-2014, 07:02 AM | #17 | |
614
Rep 2,410
http://www.bimmerfest.com/forums/sho...0&postcount=60
07-28-2014, 07:05 AM | #18 |
614
Rep 2,410
Interesting. Maybe the leaking pipe threw off your air/fuel mixture from what the system thinks it should be doing (the air mass flowing by the MAF will be lower than what gets to the intake due to the leak) which could mess up the injector calibration routines? Not sure how much of a leak you had... was it really bad?
